GSK springs
I am playing with a truck that has had the GSK 3000 kit already installed in it. My Question is What are the symptoms if the springs are too tight and also if the springs are to loose? Is there a benifit if they are say 1 click looser or 1 click tighter?
Thanks for any and all help |
When mine in the 97 were too tight it made it idle at about 550 RPM.
Chris |
When i had 98 and i had the springs too tight it would idle fine but as soon as you touched the throtle it wouls idle up to 2k and stay till you put a load on it.
Originally Posted by xzaq103
(Post 1971229)
Chris We bumped up the idle screw a little. Problem solved. |
Mine would wind two 2k as well after tring to tweak the idle screw.
