Grid heater and Fuel Pressure...
Old 09-12-2005, 09:51 PM
Mopar1973man's Avatar
Exclamation Grid heater and Fuel Pressure...
I fired up the beast this morning and I noticed something odd. My idling FP was at 14 PSI and the grid heaters kicked in and the FP dropped hard to about 11 PSI. Then when the grid heater turns off the fuel pressure bounced back up again to 14 PSI... The cycle continues as long as the grid heaters came on...
I figuring it's normal cold start cycle... But I better ask the guru's here about it too... Just really odd to se the FP and the VOLT gauge drop together.
NO my fuel pressure guage is NOT ELECTRICAL... It a mechincal DiPricol...
Is it that the GRID heater are stealing all the power from the lift pump???
OK guru's what the answer here?
Old 09-12-2005, 10:08 PM
phox_mulder's Avatar
Based on my experience last year with the new guages, a little pressure drop is normal,
as the grid heaters do steal quite a bit of juice.
phox
Old 09-12-2005, 10:11 PM
bentwings's Avatar
Mine does the same thing inthe winter. I think the grid heater will come on when it is really cold if you are below 15 mph too. Not sure just how this works howwever.
bentwings
Old 09-12-2005, 10:26 PM
BigBlue's Avatar
It's just the amount of juice the grid heaters draw. Mine does the same thing. Nothing to worry about. Now if the pump keeps doing that after the heaters turn off, then I'd be worried.
Old 09-13-2005, 08:24 AM
Wink
Nope it bounces right back... So I guess nothing to worry about then... Thank guys for the repsonses...
SpeedyWS6
15
02-02-2011 07:22 PM
Ramrod90
02-03-2009 07:39 AM
farmer dave
02-21-2007 06:16 PM
GMScott
01-15-2007 12:50 PM
taildragger
12-04-2006 10:00 AM
Quick Reply: Grid heater and Fuel Pressure...
