GetRag Oil Reccomendations????
Old Apr 9, 2008 | 11:18 AM
92GhostRyder's Avatar
Howdy folks i got thise 92 thats new to me and it has the GetRag tranny. I was curious what the heaviest lube i can run in it would be. I pulled up the factory spec on my computer at work and it brought up like 5w-30 motor oil. I dunno about ya'll but that seems a lil light for a 3/4ton and 1ton truck transmission I talked to a local tranny guy and he said he's familiar with this transmission and said i could run 90 weight gear oil. Anyone done this with no problems? Anyone know better than to do this and know what the heavist oil i can run is? just let me know thanks.
~Phil
Old Apr 9, 2008 | 11:57 AM
Alwaysworking's Avatar
alwaysonDTR
i run gear oil, thats why they made it for gears but most every one else runs a synthetic and runs a quart over full, i don't with gear oil yet. they just shift a little harder than if it had synthetic in it, because gear oil has to warm up.
Old Apr 9, 2008 | 12:16 PM
pwrtripls1's Avatar
I run Royal Purple 75-90 MaxGear in mine and like said above, its just a tiny bit stiff till it warms up some, but I trust heavy weight RP oil with harsh treatment than I trust 5w30. I've read where lots of people have run a few hundred thousand miles with 75-90 in there getrags with no problems. Mine still feels like new and has no slop in the shifter.
Old Apr 9, 2008 | 04:05 PM
Run 5W-30 synthetic motor oil.
Old Apr 9, 2008 | 05:29 PM
MoparMarv's Avatar
5w30 synthetic. And overfill it by an extra quart. Mine is apart right now. before I put the top cover on I'm going to dump the oil in the top and see where it comes too in the case so I can make a good gauge for checking the level. The oil has to get in some small and tight places in the getrag thick oil might have a hard time doing. We will see how long everything lasts in mine after its freshening up.
Old Apr 9, 2008 | 07:52 PM
Oldschooldodge's Avatar
I run 4.5 quarts of Wal-Mart brand full synthetic 5W-30 motor oil. I don't know if it was the change to synthetic, overfilling by a quart, or a combo of the two, but my tranny shifts a lot better now. Before my truck was hell to get in reverse, now it falls right in with a little pressure.
Old Apr 9, 2008 | 08:42 PM
feveree40's Avatar
There are also lots of bearings in the getrag which would rather swim in 5w-30. I ran some regular 5w-30 for a couple hundred miles after I rebult my getrag, then flushed it and overfilled with mobile 1 5w-30 synthetic. Shifts much smoother and is a little quiter with the synthetic.
Old Apr 9, 2008 | 10:51 PM
To tell the truth I dont care if it shifts like its mud LOL. I would just figure gear oil would offer more protection for a 3/4ton and 1ton tranny than a motor oil that I woudnt even run in a honda. Maybe thats just my opinion. So in other words theres no one who has seen concrete proof that its tranny suicide to run gear oil in the getrag?
Old Apr 9, 2008 | 10:54 PM
stackx2's Avatar
i run red line MTL never had any problems
Old Apr 9, 2008 | 11:18 PM
alwaysonDTR
okay i bought mine with 228,000 miles on it, i was told it had a rebuilt trans but it didn't growld a lot in third at low rpm all with gear oil. and at about 240,000 i had to pull the trans because the first and second gear shift fork roll pin broke, at this time i re-shimed the bearings, no more growl, i have been towing most of the time with it about 11,000lbs and i have no problems except it shifts hard when cold. if they run gear oil in a semi trans and rear ends i will too.it now has 278,800 plus miles.
Well i appreciate all the help guys its really been a tuff one. Like i said buncha guys tellin me to run motor oil and theres a local transmission guy been in it for years and is familiar with these things told me to run gear oil so i been a bit unsure on this one.
Old Apr 9, 2008 | 11:47 PM
farmer0_1's Avatar
i run mobile one 5-30wt quart and a half overfull.
Old Apr 10, 2008 | 12:12 AM
Fred Swanson's Avatar
Mobil1 5W30 overfill by one here, too.
Old Apr 10, 2008 | 08:25 AM
Featherman's Avatar
Amsoil 5-30, overfill by one quart as recommended by the "membership"
Old Apr 10, 2008 | 10:27 AM
carl48's Avatar
i have a 91 using 15-40 amsoil 1 quart over full with 875,000+ miles on it pulling heavy
