what gear ratio ?????
Old Jun 1, 2004 | 05:28 PM
dynamike's Avatar
Question what gear ratio ?????
looking at buying a 2002 CTD, 4x4 with an auto tranny
does anyone know what gear ratio these trucks usually come with?? How can I tell ?? Any markings on the rearend??
Thanks!!!
Old Jun 1, 2004 | 05:47 PM
3.54 or 4.10. Should be a sticker under the hood or inside the glovebox door. That same sticker will also tell you whether or not it has an LSD (posi) rear end.
Old Jun 1, 2004 | 06:49 PM
phox_mulder's Avatar
More than likely it is the 3.54 if it has the auto transmission.
2002's have the sticker in the glove box.
phox
Old Jun 3, 2004 | 12:13 AM
HOHN's Avatar
There's also a little metal tag attached to one of the diff cover bolts that has the gear ratio on it.
JLH
Old Jun 3, 2004 | 09:07 AM
RowJ's Avatar
If you can't tell by any of the above, Test drive will confirm...75 mph at 2000 rpm +/- = 3.55 rear end.
When I bgt my 02, could not read the glove box sticker and no tag on differential cover.
You can also get a "Build Sheet" from dealer (Parts Dept.) at no charge; just give them VIN #. It lists all factory options including rear end axle & gear ratio.
Rowland
Old Jun 3, 2004 | 05:42 PM
FRANKV469's Avatar
or, you can call your local dealers service dept and give them the vin--they can tell ya over the phone
design
32
Jun 23, 2003 10:07 PM
mbw
Mar 5, 2003 05:38 AM
Garz
Feb 3, 2003 09:08 AM
Cutthroat
Jan 8, 2003 09:37 AM
accordionjohn
Oct 7, 2002 12:54 PM
