Gear Lube change
Old Mar 12, 2007 | 07:43 PM
MoparMarv's Avatar
Gear Lube change
I'm going to change the oil in the transfer case, and front and rear diffs. I looked around on here and it looks like any oil thats GL-5 will do. I'm thinking about going with 75W140 synthetic all around. Truck is driving empty most of the time. Once in a while I flat tow or move a car with a tow dolly. no plans for any towing over 4000lbs at the moment if that means anything.
Also my next question to check the rear brakes do I have to take off the diff cover to remove the axles? If so I will just do it all at once. I have not found that good of a description in the dodge service manual.
Old Mar 12, 2007 | 11:12 PM
woodrat's Avatar
no the axles will come out without taking the diff cover off.
Old Mar 13, 2007 | 06:01 PM
Can't go wrong with that oil choice.
Pull all the bolts out and whack on the end of the axle with a big hammer. The end is stuck to the hub with a gasket or RTV and may take a couple whacks to break loose. Once it drops, just pull it out. Have a pie pan or similar handy to catch the few dribbles of gear oil that will come out of the hub.
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
Mopar1973man
May 5, 2004 02:28 PM
bulabula
18
Oct 25, 2003 12:01 AM
cummins1
15
Dec 27, 2002 07:45 AM
