GDP, SP Diesel installed............
Old 01-07-2007, 02:33 AM
jlibert's Avatar
Pulled out the fass 95 and installed the Glacier system. Pretty easy install cause I already had the fass wired, and the bulkhead plumbed. Instructions says bypass was preset to 22, showing 17 on my dipricol gauge. Will turn up pressure tomorrow. Pressure with fass was 17 at idle, 10 at wot. GDP 17 at idle 15 wot. much less of a drop. Very quiet.
SP diesel module was doing some wierd things to my engine so I pulled it off. At idle, the rpms would jump up like somebody was tapping the gas pedal. There must be some kind of interferance or something. Pulled it out, no issues. Will call SP on monday. Rail pressure gauge worked good, saw 23k at wot with my modded pump, no added pressure. An analog gauge would be much easier to follow, but cant beat the ease of install with the SP.
Old 01-07-2007, 11:11 AM
wap
wap's Avatar
The analog guage hooks up to the same sensor.
glad to hear the GDP kit was easy, I put in the big line and MK2 filter kit Friday night and I am goin to put in the 392 system in a couple of hours.
How do you turn the pressure up?
Dont you need shims or something from Richard?
Old 01-07-2007, 11:44 AM
jwb600's Avatar
i had the gdp 392 installed a few nights ago, I like how quiet it is. Im seeing that same pressure around 17, was 22 when 1st installed
my trk seems a little harder starting for some reason, not sure if this has anything to do with it
Old 01-07-2007, 11:47 AM
wap
wap's Avatar
Well I may not be puttin mine on today. I cant seem to find a 15/16s drill bit or a tubing cutter...
Old 01-07-2007, 12:52 PM
jwb600's Avatar
my kit came with that tuning kit, it had some washers and an extra spring, mine is the comp kit though
Old 01-07-2007, 02:14 PM
4x4not's Avatar
Unless SP Diesel REALLY changed thier products and the way they do business, I wouldn't touch them again with a 50-mile pole. I had my 4-weeks of BS with them....
Old 01-07-2007, 03:27 PM
MedicShawn's Avatar
I agree Sp Diesel is nothing but trouble poor product, poor non-available tech support send it back and buy something better that won't destroy you 40K truck. You'd be better off randomly crossing wires to see what happens. I tried their products and held out for their promises. When they wanted me to hack into their product to fix problems I sent it back.
Old 01-07-2007, 03:41 PM
973604x4's Avatar
mine seemed harder to start for the first several starts but now starts easier
Old 01-09-2007, 05:12 AM
jwb600's Avatar
you are right, it is getting easier to start now. how well do you like your turbo? I have an automatic trk as well & im thinking of getting a 62 and parting ways with my big silver bullet, I want quick spool up for the street. I dont plan to run any drugs so the 62 may be better for me.
Old 01-09-2007, 10:01 AM
973604x4's Avatar
Love it. If I want to spool and go, I can...or if I want to lug and smoke, I can do that too. Absolutely love this turbo!
crackcorn
10-24-2010 02:21 PM
DieselBoy20
15
07-20-2008 10:41 PM
13ALPHA
01-14-2008 07:46 PM
SolarYellow05
09-10-2006 09:14 AM
SSminnow
05-23-2006 10:21 AM
Quick Reply: GDP, SP Diesel installed............
