View Poll Results: Which manifold to buy?
Buy the GDP power flow manifold
27
48.21%
Buy the CFM+ without ports
18
32.14%
Don't waste my money and pass on the whole idea
19.64%
Voters: 56. You may not vote on this poll
GDP manifold or CFM+ manifold???
Old 01-27-2008, 12:27 PM
silkywoods's Avatar
which one would you go with? I am only running a 65hp quad box and will never have the need to NOS or meth.
Old 01-27-2008, 12:34 PM
MikeyB's Avatar
I'm waiting for the dyno test results on the GDP Power Flo intake which should happen this week before deciding.
https://www.dieseltruckresource.com/...=185546&page=4
MikeyB
Old 01-27-2008, 12:43 PM
jmccart's Avatar
MikeyB
X2 on that one.
Old 01-27-2008, 01:19 PM
DTR 1st Sergeant
soulezoo's Avatar
Having the CFM+, and seeing the difference, I now know conclusively that it was worth the money.
Having seen the dyno results of some of the other intake horns, I also now know they are not created equally. Some give more substantial results than others. CFM was just at the top of those tested.
Having now seen one of the CFMs come apart, I am not having a lot of warm fuzzys about it.
Seeing the design of the GDP, I would hazard a guess that it will certainly improve flow over the stock (you really have to pull the stock horn and look at the inside to appreciate just how restrictive it is) but will not be as good as the CFM... But I picked Green Bay over NYG too...
Old 01-27-2008, 01:36 PM
BRT
BRT's Avatar
I got a GDP sittin here still trying to decide what to do.
Old 01-27-2008, 02:01 PM
bob4x4's Avatar
Won't ever see one of these on my truck
Bob
Old 01-27-2008, 02:04 PM
preloader's Avatar
Just installed the cfm+ and I don't notice any diffrence.
Old 01-27-2008, 02:05 PM
preloader's Avatar
Maybe I should have went with the blade runner.
Old 01-27-2008, 02:32 PM
jlibert's Avatar
the main reason I went with the GDP is because of the 2mk filter housing attachments already in place. We'll see if there are any increases shown on the dyno tomorrow. With your mods, I can think of 10 other things i'd buy with that money 1st, including: A 2 micron aux. filter, lift pump, or money towards a smarty. Just my opinion...
Old 01-27-2008, 06:03 PM
D45
D45's Avatar
http://www.cfmplus.com/
http://www.cfmplus.com/CFM+%20User%2...n%20Manual.pdf
"CFM+ Limited Warranty":
"This Intake is not intended for use in any competitive event or activities.
This limited warranty is void where the Intake has been used in any of
these ways"
Old 01-27-2008, 07:20 PM
foolkiller's Avatar
i have the GDP unit.....
judging by the craftmanship alone, there is no way it'll perform as well as the CFM. the flange and the pipe are not machined to match and there is a lip interupting air flow at the weld.
i do believe it flows better than the stocker and noticed more pull on the top end. reports on the CFM are that you feel increased pull top and low.
i wish i'd have went for the CFM like i wanted to.
j
Old 01-27-2008, 08:16 PM
BRT
BRT's Avatar
I was debating whether to send the GDP back or not , but it'll go on.
I just filed the flange to make sure it was truly flat, the just blended the lip with a die grinder and good to go.
I do agree that the CFM as well as others probly does flow way better , but how much do I really need with the stock tranny.
I mean , if I really jump on it I can break the duals loose and slip the TC if I really try.
Honestly, I didn't really need the intake , may not even feel any different, but heck , it's a cool add on and conversation piece combined with the delete so I figured why not. Everbody else is doin it.
See what ya'll do to me??
Make me spend money on my truck.
Old 01-28-2008, 04:08 PM
MikeyB's Avatar
Do we have a dyno update for the GDP intake yet?
MikeyB
Old 01-28-2008, 04:20 PM
DevilzTower's Avatar
anxiously awaiting the same info ...mikeyB
Old 01-28-2008, 04:21 PM
jlibert's Avatar
not yet. I'm leaving here in 30 minutes and it takes about 1.5 hrs. to get to Erik's shop. Should have results tonight.
Quick Reply: GDP manifold or CFM+ manifold???
