Gaskets for HX-35
Old Sep 27, 2010 | 01:09 PM
JonathanFleguel's Avatar
Gaskets for HX-35
im putting a hopped up HX 35 from a buddies truck in mine and would like to know the part numbers for the manifold to turbo gasket the oring and the gasket for the drain. correct me if im wrong but thats all i need to do. also how do i set the wastegate or even check if it works. thanks. jonathan
Old Sep 27, 2010 | 03:12 PM
i think im gonna try bigbaddiesels idea and reuse the manifold gasket and cut a drain gasket
Old Sep 27, 2010 | 04:41 PM
92roughstock's Avatar
I use anaerobic sealer on the drain gasket- that way, you'll never have to scrape off old gaskets ever again.
The turbo to manifold gasket it reuseable, kind of. Put it on and see if you get any leaks.
Old Sep 27, 2010 | 06:12 PM
dodgethis91cmns's Avatar
is anaerobic a fancy term for RTV?
Old Sep 27, 2010 | 07:15 PM
The Dodge dealer has new ones for an OK price...
I would not reuse the manifold gasket, it crushes to seal and they often leak on the second try.
Old Sep 27, 2010 | 08:56 PM
92smokin blacky's Avatar
use them. I put some high temp silicone on the manifold gasket everytime, changed my turbos 4 times and no leaks. And for the oil drain just cut your own gasket out of the gasket paper stuff, and put some gasket sealer on both sides and it'll be fine.
Old Sep 28, 2010 | 08:22 AM
kensmachine's Avatar
Whene I did turbo repair Told my costumers Never use RTV on the drains of Turbos. why most pepole put way to much RTV on and I have seen the oil inlets and outlets pluged or almost pluged with RTV.Ken
SmokinDodge12V
15
Mar 9, 2004 08:39 AM
carl20320
Feb 25, 2004 02:35 PM
shaft
13
Jan 29, 2004 07:37 AM
srowen
Jun 27, 2003 06:44 PM
mymaur
Dec 23, 2002 08:28 AM
