3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
G-56 & Hp/tq
Old Mar 27, 2009 | 04:19 PM
LFD2037's Avatar
G-56 & Hp/tq
How much extra HP/TQ can a stock G-56 handle before the clutch starts slipping/ letting go?
Old Mar 27, 2009 | 04:24 PM
diggity dodge's Avatar
50-75hp With No Abuse
Old Mar 27, 2009 | 05:16 PM
LFD2037's Avatar
That's it? I thought the G-56's were tough as snot!
Old Mar 27, 2009 | 05:19 PM
annabelle's Avatar
Not the clutch.
Old Mar 27, 2009 | 06:01 PM
Bswope's Avatar
Mine held the Smarty/TST stack, when I swapped it for the DD it was actually still in pretty good shape!
Old Mar 27, 2009 | 06:10 PM
LFD2037's Avatar
That makes me feel a little bit better.
Old Mar 27, 2009 | 06:35 PM
nelrod's Avatar
Transmission can handle a lot more power, but, as Annabelle said, clutch was not set up to hold a lot more, just like previous Dodge CTD transmissions.
Old Mar 27, 2009 | 08:28 PM
Hintz's Avatar
NO, not at all a lot of people once they get 600+ and start drag racing them or sled pulling the casings start splitting in half
Old Mar 27, 2009 | 10:00 PM
Bjans's Avatar
How can you tell which trans you have g 56 or nv 5600?
Old Mar 27, 2009 | 10:12 PM
rich's Avatar
g56 reverse is lower left, late 05 and up, believe in the oct 06 made trucks have the better overdrive
Old Mar 27, 2009 | 10:18 PM
coblanchard's Avatar
My stock clutch wouldn't hold software #2 on the smarty jr, and this was just layin on the throttle going down the highway without towing anything.
Old Apr 4, 2009 | 01:19 PM
Joe Reitman's Avatar
Probably depends on what gear you are in when you hammer it. I have the Dr. Performance Stage III 110/220 module, but never hammer it in 6th, and only really hammered it in 5th once. Seems like if you just get on it hard in 2-4th there is less load on the clutch. That's my theory anyway.
Not that I would try to sled pull or drag race on a stock clutch anyway...
Old Apr 4, 2009 | 05:16 PM
Tacsavage's Avatar
Nope. A lot of failures in these things. Seems like 4th gear is a common one to go. 600hp seems to be the point at which a lot have failed. Tac
Old Apr 4, 2009 | 05:20 PM
Boz007's Avatar
Weird. Mine held software #7 on 35's for quite some time. When i put the 37's on it decided to quit.
Old Apr 5, 2009 | 09:10 AM
CaptainKelley's Avatar
Smaty jr on 3 will slip at will. Holds two pretty good. Set on 3 at 80% pod dosent slip but something is getting bound up because once in a while i cant push the clutch in.Like the throw out bearing is binding. It's going in tomorrow for a new clutch. Will post new thread on the results.
