G-56 fluid change???'s
Old Dec 10, 2006 | 09:33 PM
06dually's Avatar
It says in the owners man. that it has mopar ATF+4 in it now. What would be the Amsoil equvilant for fluid?? And what would be the capacity??
Old Dec 11, 2006 | 07:27 PM
texasredrider's Avatar
i was wondering the same thing and also do we stll need to over fill it by 1.5qts through the shifter tower, or has someone figured out an eisier way?
Old Dec 11, 2006 | 07:36 PM
bluebull's Avatar
Amsoil ATF universal fluid.
Not sure about capacity.
Fill through the top PTO cover bolt.
Old Dec 11, 2006 | 07:49 PM
CD in NM's Avatar
Amsoil Universal ATF, 6 quarts. You can top off the tranny by putting 2 wheels up on a curb or block making a side tilt instead of going through the tower. I installed a set of Fast Coolers with my G56 tranny fluid change, added more capacity and cooling. I also added a temp sensor at the same time.
CD
Old Dec 11, 2006 | 08:48 PM
XLR8R's Avatar
Fast coolers rock!
Old Dec 11, 2006 | 09:29 PM
so is that 6quarts before you added the fastcoolers or after?
Old Dec 11, 2006 | 11:54 PM
XLR8R's Avatar
Fast coolers add one quart per side.
Old Dec 12, 2006 | 12:55 AM
Sloverado's Avatar
Where are you guys getting the Fast Coolers? I have only seen them for the NV5600.
Old Dec 12, 2006 | 06:56 AM
CD in NM's Avatar
I got mine directly from Fast Cooler. You have to also get the kit for the G56, includes metal spacers(gasket like) and metric bolts. I contacted Geno's and they told me they were not available for the G56 so I contacted Fast Cooler. http://www.fastcoolers.com/index.html
CD
Old Dec 12, 2006 | 09:00 AM
So a stock G56 holds 4 quarts, correct? does that include the extra 1.5 quarts they had to add to the early 05's that had a hold on them for dry bearings causing the main bearing failure? then the fastcoolers would add 2 more to the 4, making a total of 6 quarts with the coolers installed. OR is it 6 quarts with a stock G56, then 2 more if you have the coolers for a total of 8 plus the 1.5 extra which would then make it 9.5? I think i just confused myself!
Old Dec 12, 2006 | 09:38 AM
2broke2smoke's Avatar
6 Quarts Through The Fill Plug
Old Dec 12, 2006 | 09:40 AM
XLR8R's Avatar
The coolers fit both the NV5600 & the G56.
Old Dec 12, 2006 | 09:41 AM
XLR8R's Avatar
Just keep adding ATF+4 'til it leaks out the shifter ****...
LockedandLoaded
Jan 17, 2008 02:51 PM
markm4
Jul 29, 2007 11:16 AM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
