Fuse pannel or ignition switch problem?
Old 05-08-2006, 10:20 AM
Nicaraguan_Farm's Avatar
2001 RAM 2500 diesel 4X4 manual:
50% of time when I start truck, the following will not work: air cond, horn, speedometer, electric windows. I then go pull fuse #12 ? and that kills the engine. I replace the fuse and start the truck again and 50% of the time all will work except the right electrinic window.
If upon restarting the truck the above stuff noes not work, I pull the fuse and put it back in and keep pulling and replacing until they work.
Is this the fuse pannel or ignition swithc or what?
I can not take to dealer because the truck in Nicaragua and there is no dealer.
Help please
Old 05-08-2006, 03:59 PM
gcookieman's Avatar
Did you check the main connection at the power dist center ? It comes straight off the battery. Clean thoes real well also clean fuse contacks.
Where are you in Nic? I have been a few times on mission trips.
Sean VHA #60013
09-27-2009 09:41 AM
Diesel Jeff
07-25-2008 02:59 AM
wrangler04
07-19-2007 08:50 AM
CTD2001
05-08-2005 07:59 AM
jd03ctd
05-10-2004 08:06 AM
Quick Reply: Fuse pannel or ignition switch problem?
