Full Load diaphram adjustment
Old Jul 14, 2003 | 01:38 AM
carl20320's Avatar
Took a peek at my full load diaphram this evening. Somewhere I read that the index mark was supposed to be at the &quot;12 o-clock&quot; position (toward the intake manifold). Well, my index mark is at the 8 o'clock position. Is there really any hard and fast rule on where the stock setting for this is? Should I jsut proceed to rotate 90 degrees closckwise (initially). I would, of course) mark the position of the original just to have a reference to return to if necessary.<br><br>Carl
Old Jul 14, 2003 | 05:17 PM
Monty's Avatar
Re:Full Load diaphram adjustment
Carl, <br><br>All those settings are telling you is, is to make the fuel pin ride up the eccentric cone on its &quot;deepest&quot; setting. Take the cone out of the pump. Looking at the cone, you will notice that it is much like a cam, with one deep side and one shallow side. Now, look into where the cone was pulled out of. You see that hole at the bottom going towards the front of the truck? That is where the fuel pin comes out under boost conditions. Now, look at the cone and turn it so that the pin will have the most travel out of its hole and onto the cone, or should I say deepest travel. Once you have found deepest travel, insert the eccentric and take a paint pin and mark it on the diapraghm.
Old Jul 16, 2003 | 11:51 PM
Bushy's Avatar
Patron Saint of 1st gens
Also, if you wipe the cone off after removal, you should see some &quot;witness marks&quot; on it. That is mark left by the guide pin as it rides up and down on the cone. You want to have the pin, as mentioned, riding up and down on the deepest part of the cone. This permits the fueling rate to be set at it's maximum. This is &quot;fuel per pound of boost&quot;.<br><br>Bob, Pastor<br>Our Lady Of Acceleration Church.
440forPOWER
Jun 15, 2006 11:04 PM
ruquik
Feb 22, 2006 05:03 PM
BearKiller
Jan 29, 2006 08:24 AM
plow
Jan 21, 2006 06:46 PM
racermatt2606
0
Oct 5, 2004 06:10 PM
