Fuel tank vents
Old 02-03-2010, 07:02 AM
riddle family's Avatar
Question Fuel tank vents
Guys, how do you recommend to clean the fuel tank vents? Can I use a carb cleaner and then try to blowout with compressed air or are there better ways?
The truck has shut down on me 3 times in the past 2 days cruising to a stop. No codes, FASS sounds fine but I think I am cavitating the pump causing a lose of fuel pressure. When it does it I can fire it right back up.
Thanks,
Dwight
Old 02-03-2010, 12:28 PM
Anybody?
Old 02-03-2010, 02:02 PM
CamperAndy's Avatar
Drive with the cap off. If it dies again it will not be due to the pump cavitation.
Also since the tank is plastic you would see it collapse before the pump failed to move fuel.
All that said your pump could be dieing but I don't think it is due to a plugged vent.
Old 02-03-2010, 02:41 PM
I hope it is not the pump. The FASS has only been on since August of last year. Be really ****** if it goes out on me.
hognutz
09-15-2009 06:53 PM
Grey Goose
08-20-2009 09:43 PM
beardedone
08-28-2008 07:16 PM
nvr-enuf
12-22-2007 10:26 AM
wrighttts
02-20-2006 11:19 AM
Quick Reply: Fuel tank vents
