Fuel tank vents
Old Feb 3, 2010 | 07:02 AM
riddle family's Avatar
Question Fuel tank vents
Guys, how do you recommend to clean the fuel tank vents? Can I use a carb cleaner and then try to blowout with compressed air or are there better ways?
The truck has shut down on me 3 times in the past 2 days cruising to a stop. No codes, FASS sounds fine but I think I am cavitating the pump causing a lose of fuel pressure. When it does it I can fire it right back up.
Thanks,
Dwight
Old Feb 3, 2010 | 12:28 PM
Anybody?
Old Feb 3, 2010 | 02:02 PM
CamperAndy's Avatar
Drive with the cap off. If it dies again it will not be due to the pump cavitation.
Also since the tank is plastic you would see it collapse before the pump failed to move fuel.
All that said your pump could be dieing but I don't think it is due to a plugged vent.
Old Feb 3, 2010 | 02:41 PM
I hope it is not the pump. The FASS has only been on since August of last year. Be really ****** if it goes out on me.
hognutz
14
Sep 15, 2009 06:53 PM
Grey Goose
Aug 20, 2009 09:43 PM
beardedone
Aug 28, 2008 07:16 PM
nvr-enuf
Dec 22, 2007 10:26 AM
wrighttts
Feb 20, 2006 11:19 AM
