Fuel Tank Tips ?????
Old Dec 10, 2008 | 02:45 PM
3ton1/4's Avatar
Got to drop my fuel tank to fix a leak. Anyone got tips ? Should be pretty straight forward huh ?
Old Dec 10, 2008 | 03:02 PM
dozer12216's Avatar
Pull the bed instead. Six bolts and a wire or two gets you there. OH yes, Three helpers and move backwards onto saw horses. Much quicker and not near as much mess and fuss.
Old Dec 10, 2008 | 03:29 PM
1-2-3's Avatar
Just a plain ole guy
Where is the leak? if it's on top make it into a vent.
Old Dec 10, 2008 | 04:35 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
if you drop it, only do one side of the straps and make sure its empty as you can comfortably handle. use a floor jack and plywood to let it down a bit to disconnect the wires, etc. at the top.
Old Dec 10, 2008 | 05:54 PM
rich's Avatar
its not that hard jack up the truck some to make it easier, i did it by myself and held the tank up it doesnt weigh that much hardest part is disconnecting the fuel lines becareful they will break
Stamey
Jun 27, 2008 02:04 PM
tswan
Feb 7, 2008 10:50 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
