Fuel Pop-off Valve
Old Jul 26, 2004 | 06:16 PM
97RAM's Avatar
Fuel Pop-off Valve
Anyone with bad fuel mileage try replacing the fuel preasure pop-off valve yet?
I mentioned the rumor to my dealer and they ordered me a new valve just to see what happens.
Will let you know after it's done.
Cheers,
RH
Old Jul 26, 2004 | 08:46 PM
RankRam's Avatar
Sounds like a great dealer!
Please keep us posted.
Thanks.
Old Jul 27, 2004 | 01:32 AM
BiggRigg600's Avatar
Yeah, by all means, please keep us updated... my already poor mileage is getting even worse lately @ 5K miles... back down into the mid 12's, even running empty on the hwy... this is getting really old... thinking of switching back to my gasser (which is still for sale) as it gets BETTER mileage than this thing
Old Jul 27, 2004 | 10:01 PM
J BODY's Avatar
If you are talking about the "pressure limiter valve" it's not going to have any effect on mileage. Matter of fact if it leaks your truck will not run right if at all. It is a mechanical safety device that allows excessive rail psi to bleed by. Trouble is when the psi "bleeds" by were talking psi that can be in excess of 25,000 lbs. This high psi tends to actually cut the seat in the valve causing it to leak. I've replaced two of these valves on the common rail fuel systems that were running mods.
Old Jul 28, 2004 | 11:01 AM
stevenknapp's Avatar
JBody, there was a tuner in another forum that mentioned that the pressure it was releasing at was too low for some of the valves, a manufacturing defect perhaps?
Old Jul 28, 2004 | 06:13 PM
Mark Thomas's Avatar
anyone know what this pop-off valve costs?
Old Jul 29, 2004 | 01:40 AM
J BODY's Avatar
Was this discussion at TDR? I would like to read up on this theory.
Old Jul 29, 2004 | 10:59 AM
NJMurvin's Avatar
I believe it was the Dieselram website. The first I saw was a post by Ted Jannetty. He said that they had seen or heard of some bad ones. I actually started thread over here on the subject, but it died.
Here's the thread
Neil
Old Jul 29, 2004 | 08:58 PM
J BODY's Avatar
Interesting. The two I replaced were towed in and the leakage through the psi limiting valve was even noticable cranking.
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
Lark
Mar 2, 2007 07:26 AM
kwikspool
13
Jan 6, 2005 07:04 AM
NJMurvin
13
Jul 12, 2004 07:31 AM
