Fuel Hose
Old Dec 14, 2005 | 04:39 PM
ViperSBT's Avatar
Fuel Hose
OK, so I am going to replace all the lines to and from the fuel tank on my buddies '89. Can anyone point me to the proper size hose that I should be using for this?
Old Dec 14, 2005 | 04:49 PM
Underpsi's Avatar
im not certain but i think if u go to a larger size it is better for the fuel pump cuz it helps lubricate it better I may be wrong tho. I know the famous KTA upsized his lines to 1/2 but he had to up the fuel pickup tube as well. Its just a thought cuz it would be the best time to do it.
Old Dec 15, 2005 | 04:32 AM
banzaitoyota's Avatar
I just did my lines on my 92. Ran 3/8" Nylon. Purchased it from the local hydraulic supply store
Old Dec 15, 2005 | 11:52 AM
norberg's Avatar
I recently ran 1/2 fuel hose with a new pickup.
Why are you replacing the lines?
the stock lines on my truck are metal, with rubber hose on both ends.
if you are having leaks, replace the rubber parts.
unless you want more fuel flow, than go with a larger than stock diameter
I think stock lines are 5/16
but I am not positive
Old Dec 15, 2005 | 11:59 AM
Underpsi's Avatar
did you run 1/2 metal and rubber lines or just rubber? did you just run 1/2 to the filter or all the way to the injection pump?
Old Dec 15, 2005 | 12:30 PM
On the 92, the lines are 5/16 nylon, NLA from the dealer.
Old Dec 15, 2005 | 12:49 PM
norberg's Avatar
I ran 1/2 rubber lines to a new larger fuel filter before the lift pump.
coming out of the new filter I used 3/8 line to the lift pump.
even though the lift pump uses 5/16 line the 3/8 works with a good hose clamp.
next I intent to install high flow banjo bolts!
Old Dec 15, 2005 | 02:06 PM
Underpsi's Avatar
im thinking of skipping the banjo bolts and go to open fittings. is there a negitive side effect to that?
Old Dec 15, 2005 | 07:36 PM
rockjeep73's Avatar
That's a good question. I wouldn't think so, because I am also gonna run the open(AN) fittings.
Old Dec 15, 2005 | 09:04 PM
Underpsi's Avatar
i couldn't see any negitives either and it will be alot less hassle then to use banjo bolts as well as flow better. i have a ton of fitting in the shop so i have lots to play with. i plan on doing this when i install my lp. I've been busy with school lately so I haven't had the chance. During the christmas break it should be done and i'll let everyone know how it went
MileGrinder
Jun 2, 2013 09:19 AM
stroker4501
Feb 13, 2007 04:33 PM
george7941
Aug 10, 2005 07:06 PM
JohnnyH
May 23, 2004 06:09 PM
