Fuel Gauge Reading Question
Old Jan 3, 2003 | 07:31 PM
NWDave's Avatar
Recently installed my mechanical ISSPRO Fuel Pressure Gauge. In the process of learning what is normal and acceptable readings with all these gauges. I do have a question about the Fuel Pressure readings. I've noticed that for about the first five minutes of easy driving, the fuel pressure is under 10 lbs and when I slightly accelerate, certainly not WOT, it drops to about 5-6 lbs, wobbles a little then returns to about 10 when I ease off the pedal. After this initial &quot;warmup&quot; period of 5 minutes or so, everything settles down to 15 idle, 10 WOT and about 12 cruising along (60-70 mph). Are the fuel pressure readings during &quot;warmup&quot; what I should be seeing? Personally, I think I'm getting a little paranoid about the pressure readings and am looking for a comforting comment about I'm doing just fine. <br><br>~dave
Old Jan 3, 2003 | 07:39 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Fuel Gauge Reading Question
Not sure what's going on there.
I'm also using the Isspro mechanical FP guage, and I've got a rock-solid 15 psi when it fires up.
What point are you using to pick up pressure?
Right now I'm pre filter at the filter canister.
Soon to change to post filter.
Old Jan 3, 2003 | 08:04 PM
NWDave's Avatar
I'm post filter at the inlet to the Fuel Injection Pump. Remember, there is a filter design change between your 99 and my 01.<br><br>~Dave
Old Jan 3, 2003 | 08:45 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
I've seen this numerous times, Dave, with numerous fuel systems. Some seem to do, others don't. It may have something to do with climate. Cooler weather thickens the fuel a bit, causing lower pressures until the fuel heaters kick in and the fuel warms up.
Old Jan 3, 2003 | 08:47 PM
Shovelhead's Avatar
Maybe the Blue Indonesian wool fuel heaters would alleviate the trouble.
Old Jan 3, 2003 | 08:56 PM
Scotty's Avatar
Top's Younger Twin
Then theres my fuel system.<br> bent from day one 10 psi at idle 10 psi at cruise never below 7 psi at WOT with TST COMP and DD 3's and recovers quick.
Old Jan 3, 2003 | 08:59 PM
Shovelhead's Avatar
So now it's the CC II air filter system? ;D
I'm gonna get me a clear one.
Old Jan 3, 2003 | 11:19 PM
Scotty's Avatar
Top's Younger Twin
[quote author=Shovelhead link=board=7;threadid=9165;start=0#88099 date=1041649165]<br>So now it's the CC II air filter system? ;D<br>I'm gonna get me a clear one.<br>[/quote]<br><br>Someone infiltrated and changed my name... :'(<br><br>LOL
Old Jan 4, 2003 | 06:11 AM
Shovelhead's Avatar
Warning to the name-changer:<br>Beware of people who can lift heavy objects, and flip over cars. :-X
Old Jan 4, 2003 | 06:50 AM
NWDave's Avatar
Ok, so I'm getting these warm fuzzies about this condition. Thought it was something like that. Now, about the blue indonesian wool fuel line sweaters. <br><br>Thanks guys. <br><br>~Dave
Old Jan 4, 2003 | 11:44 AM
chuck3's Avatar
Dave, It is not uncommon to see 1 to 2 psi less when starting in cold weather, but your seems a little more than normal but you could still have a little air in the sender line.
6.7L dodge
Mar 28, 2015 09:36 PM
mullishacrew
Mar 18, 2012 12:41 PM
Diesel dad
Feb 12, 2009 09:08 PM
big red psd cc
Feb 25, 2005 11:41 PM
mitchkim
Aug 30, 2004 05:51 PM
