Fuel Filter
Old Jun 4, 2004 | 04:54 PM
twhite's Avatar
Fuel Filter
I have replaced my fuel filter 6 times. 2 of the 6 times the truck would not start. I alternated between cranking on the starter and "bumping" the starter. The truck eventially started.
What procedure should be followed so that the truck starts every time after a fuel filter install? Should I have a supply of diesel fuel on hand to top off the filter canister? Maybe it didnt start because I had allowed air in the fuel line.
Tim
Old Jun 4, 2004 | 06:11 PM
nitrousn's Avatar
all i do is bump the starter and let the pump run for the timed out 25 seconds. i do that 3 times and mine fires up ok.
Old Jun 4, 2004 | 09:32 PM
thumper 549's Avatar
I take it you do not have a fual P. guage??...this is a bad lift pump in my exp.-----mine did the same thing, had to crack the inj. and all that till I figured out the lift pump had no preasure!!
Old Jun 5, 2004 | 04:42 AM
twhite's Avatar
It had only happened a couple of times after changing the fuel filter. I have no other problems with the truck that I know of. You think I might have the beginnings of a bad lift pump?
Tim
Old Jun 5, 2004 | 12:09 PM
Dr. Evil's Avatar
Tim,
Make sure you fill your fuel canister with fresh diesel before you put the cover back on. If you do this you wont have any starting issues.
Old Jun 5, 2004 | 12:22 PM
jigdog's Avatar
tim look at this lp test its easy to do to see if you have a pump that is working at all. pull the line to the injector pump off (either end of #5) then put a container under it incase the pump works it should pump out 1.43 liters when you bump the starter if it doesn't you are in need of a pump. hope this helps
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
