Fuel Filter
Old 03-13-2009, 09:47 PM
RAFTEN's Avatar
Fuel Filter
Someone told me the 6.7's have a plastic screw on fuel filter, is that correct?
Old 03-13-2009, 10:22 PM
tnhtractors's Avatar
Yes they are plastic, and easy to change, I have 68000. miles on my 08 and I have change the fuel filter 6 times and never made a mess changing it. The plastic case is very durable. You just drain the fuel out, unplug the sensor, then unsrew whole filter and install new one. They cost around $28.00
Old 03-16-2009, 08:13 PM
ken7728's Avatar
fuel filter removal
Can someone tell me how to get the wire connector on the bottom of the fuel filter loose. I can't see in there and this afternoon I was trying to squeeze it on the bottom and could not get the connector loose
Old 03-16-2009, 10:02 PM
there is a little clip just like the other connections, you your probably doing it right, just squeeze it and pull down while wiggling it. sometimes it easy to go in through wheel well.
Old 03-17-2009, 07:02 PM
38short's Avatar
Jack the truck up and crawl under for heaven sakes
Old 03-17-2009, 09:56 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Yes but PLEASE remember to use a Jack Stand
Old 03-18-2009, 07:11 AM
ChrisM55's Avatar
pull the fender liner out. It makes the whole process MUCH easier and no fuel in the hair haha
Chris
sjester
04-17-2006 10:06 AM
roc155
23
03-09-2006 06:44 AM
Lunyfringe
01-10-2005 05:40 PM
XTOAK
17
08-23-2003 09:07 AM
turbo59pwr
07-09-2003 04:24 PM
Quick Reply: Fuel Filter
