Front suspension problems
When I go over bumps every once in a while I get a clunking under the drivers side floorboard and then sometimes it will feel and sound like I am going over rumble strips but i am not. Any ideas? Any help would be awesome. I'm thinking maybe the shocks are bad. I just had my trac bar, lower control arms and u joints replaced.
Most likely a loose lower shock mount. These things have to be gorilla tight!
Might also check tie rod ends, ball joints and the list can go on and on.
Dave
Dave
I had the entire front end checked and was told everything was good. I also had them make sure the lower shock mounts were tightened to specs. However I have only replaced the shocks once
Double check the lower mounts. The torque spec will result in lots of shock movement! I can't tell you how many trucks I have "fixed" in fifteen minutes with a breaker bar with a cheater and all the lead in my rear end exerted on a couple of bolts.
But then again, it may not be the case.
Dave
Dave
Try lookin at the sway bar end links. I had a noise in mine for 3 years and couldn't see a thing, then one day I was under the truck and got a bit of a bounce out of her. I could see a lot of movement in the ball part.
That might not be your trouble though but they will clunk..
I agree with fishing.. the lower bolts take alot, use a screwdriver/prybar to try to lift up on the body of the shock down near the mounting bolt, if it moves when you pry up...its still too loose,
I just got back from a trip and I was able to determine when exactly it happens. For instance on the freeway whenever I hit a lip in the road surface like a bridge or over pass I will get the vibration and noise and it seems to stop if i hit another bump. It never happens on a smooth road and then last night when I drove over rumble strips i got the noise and it went away as soon as I hit the next rumble strip. This help at all?
Check the upper and lower control arm bushings. Have someone engauge fwd/rev and watch to make sure the axle does not rotate fwd or backwards. Pretty easy to replace and about $70.
Bushings the cuase?
Can you explain how the bushing causes this. I have this noise and the axle does rotate. I don't understand how a bushing would be the cause.
The Guru
I would see how tight the lower bolt is. Mine fell out and that was the source of the noise, for my ride. Is the rest of the front end stock? You might want to check the end links on the sway bar as they are over looked. Have you check for any worn ball joints/track bar movement?
