front end qs
Old Jan 25, 2009 | 12:41 AM
BlackRam1's Avatar
front end qs
my steering getting pretty loose havent got a chance to look just yet but what are some of the common things that go?
Frank
Old Jan 25, 2009 | 07:15 AM
dodgeguy71's Avatar
I think the most common thing is the track bar getting loose causing the imfamous "death wobble" but my truck has 123k and no issues with that. I did do an upper ball joint, just one. Best thing is to roll up under there and grab the track bar and push/pull at the joints, should have no movement up/down etc. Basically just check all steering joints.
I'm sure others will chime in shortly with more info
Old Jan 25, 2009 | 03:25 PM
wcbcruzer's Avatar
Track bar, steering box, ball joints, tie rod ends, wheel bearings, etc. The first two are amongst the most common.
Old Feb 4, 2009 | 01:06 AM
Swarthy Dago's Avatar
Change those control arms ! On your year of truck are they still a u shaped stamped out of sheet metal (spinless weak trash) like on my truck. I went with Rancho's heavy round tube ones, added zirks and saw immediate improvement with looseness.
Old Feb 5, 2009 | 08:31 AM
smokeyram's Avatar
if you lay under the truck, and have someone work the steering wheel back and forth, you will see everything that is loose. the one and only nice thing about the front ends on these trucks is that they are relatively simple.
Old Feb 5, 2009 | 10:12 AM
Crazydave's Avatar
For me, track bar, wheel bearing, ball joints
1999blackcloud
Jan 26, 2010 08:52 AM
big jimmy
Jan 29, 2006 11:17 AM
shoffs30
Sep 13, 2005 09:57 PM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
