Front Brake question
Old Nov 1, 2005 | 07:42 PM
ellerman's Avatar
What causes my inside front right brake pad to be worn twice as thin as all the other pads? Any suggestions on fixing this? The truck only has 62K on it so I hope it's not a bad caliper. Also, any sites that give instructions on replacing the front pads for an 01. Thanks, Eric
Old Nov 1, 2005 | 09:56 PM
Geico266's Avatar
The caliper is sticking, pretty common problem. You'll just need to remove the caliper (two bolts)and clean the sliding surfaces and lightly them & grease the bolts, before you replace the pads. Pretty common maintenance item, and easy to do. I think you'll need a 3/8" allen wrench adapter to fit on a 3/8" ratchet.
Don't get life time pads, they eat the rotors. You'll need to do both sides, BTW.
wannadiesel
Nov 1, 2013 06:58 PM
oldblu
Nov 10, 2010 08:59 PM
johnls
Apr 1, 2009 01:51 PM
roxxx
Mar 25, 2009 11:10 AM
HOUTEX
Mar 16, 2006 12:49 PM
