Front air springs might be the cure!!!
Old 04-10-2006, 02:35 PM
Tommy93w350's Avatar
Air Lift 1000 Load Assist Front Spring KitsSolve your suspension problems.
No matter what you drive, Air Lift 1000 Load Assist spring kits can solve your suspension problems. These air springs are inflatable air cylinders made from tough polyurethane material, and fit inside your coil springs to add up to 1,000 lbs. of leveling capacity. Each cylinder has an inflation valve, so you can vary the air pressure to level your vehicle and compensate for uneven loads. Load assists reduce roll, sway, and bottoming out, and are available for most cars, trucks, and minivans with open coil springs. They come complete with air lines, fittings, brackets, and mounting hardware.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AIR%2D80765&N=429 4908110+4294907801+4294924653+4294925130+115&autov iew=sku
Has anybody used these in their truck?? I want a stiffer suspension, sometimes,--- leveling, when not towing---adjustable, quick clean hands. My truck is nose diving, which works good towing. This lifts and stiffens the suspension.
Check it out at Summitracing.com
Old 04-10-2006, 04:49 PM
nitrousn's Avatar
You cant use them because the shock is in the center of the coil spring. The only way that i can see would be to relocate the shochs to the outside of the coil spring.
Old 04-10-2006, 08:26 PM
I forgot about that little technical problem. Thanks for reminding me.
What if I did remove the shocks and install the coil air bags. Do you think it would lift 1.5" and stiffen the ride?
Old 04-10-2006, 08:30 PM
G1625S's Avatar
Here's the top of my wish list. Someday....
http://www.keldermanairride.com/prod...hp?id=93DDGFRT
herb
07-18-2008 08:25 AM
Tommy93w350
15
07-26-2007 12:02 PM
chuxtruk
04-06-2005 05:58 PM
bigred496
10-22-2004 07:16 PM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: Front air springs might be the cure!!!
