Flywheel Shim
Old Oct 10, 2007 | 06:27 PM
AllPlay's Avatar
Flywheel Shim
I purchased a Valair 450/950 clutch. The guy that is going to help me install said after the flywheel is turned that we would need shims to make up the difference. Is there a assortment pack of shims or did anyone bother doing this. I can get various pieces of shim stock, will that work. Thanks in advance.
Old Oct 10, 2007 | 07:02 PM
Box5's Avatar
I got a valair clutch and just had the flywheel resurfaced and put it on. I guess it depends how much ur flywheel needs resurfaced. You could try these guys, i just found there website and they have shims, so give them a call to find out for sure.
http://www.hrclutch.com/Clutch-Accessories.html
Old Oct 11, 2007 | 08:04 AM
texastuff's Avatar
a new flywheel is 1.5 inches from the back where the crankshaft mounts to the top where the disc friction makes contact.
Old Oct 12, 2007 | 09:21 AM
AllPlay's Avatar
Do you know how much they took off your flywheel? Is there a min/max to look at when this happens?
Jona Gold
29
Jan 19, 2025 06:36 PM
tbishop1
Sep 20, 2005 02:16 AM
Dodge Demon
Aug 23, 2004 09:27 AM
