Fluid Damper Install ?
Old 12-16-2008, 08:30 AM
mulisha's Avatar
guys i heard that a few people had a problem with the damper flying off and breaking stuff.is that pin neccessary,what else do i need to know. thanks
Old 12-16-2008, 11:27 AM
wap
wap's Avatar
The factory bolts are TTY. Get new bolts from cummins. I think mine were around $4 a piece plus shipping.
PN 3903857
I have a pin kit, but not quite how I would drill the crank.
Pin kit PN 300002
Old 12-16-2008, 11:45 AM
RowJ's Avatar
Tty ....... ????
Old 12-16-2008, 12:14 PM
Mike D's Avatar
Tty ....... ????
Torque to yield.
Old 12-16-2008, 12:16 PM
tesla440's Avatar
TTY Torque To Yield... Basically a use one type of bolt.
That's strange, I thought that when I did my Tone Ring Mod that they were grade 5 bolts. I've retightened my up & the stock dampner hasn't had a problem yet. Look at the bolts when you take them out. First look at the head to see how many lines that are on them. From what I've seen TTY bolts don't have any lines on them. But the tell tail sign is the partail thread length with a unthread portion just between the head & the bottom threads of the bolt. This area usually have a slightly small diameter than what is used for the threaded portion. I hope that it makes seens. Otherwise you google it for more info.
Old 12-16-2008, 12:37 PM
joesixpack's Avatar
I would pin it, did mine while the engine was out, so it was simple, in the truck it would be a PITA though....
Old 12-16-2008, 01:25 PM
enafzige's Avatar
I recently pinned mine. The best time to do this is when putting in a cam. Otherwise, I think you'd have to pull the intercooler, radiator, etc.
I used a Milwaukee right angle drill, and the included bit and guide. It went really well, and is inexpensive insurance...
--Eric
Old 12-17-2008, 06:57 AM
wap
wap's Avatar
--Eric
Thanks for that info Eric, I guess I will just put in new bolts with some locktite until I get ready to put a cam in, and pin it then.
bigragu
08-30-2015 08:21 PM
dieselcarpenter
12-16-2007 10:04 AM
Jpw
18
09-13-2007 10:10 PM
Mr Bee
08-28-2007 08:02 AM
PourinDiesel
29
03-13-2006 09:04 AM
Quick Reply: Fluid Damper Install ?
