FASS - need to keep at least 1/8 tank
Old 12-05-2008, 01:08 PM
dodgerdog's Avatar
I'm about to pick up my 2001 truck after having a FASS and VP44 installed. I just got off the phone, and the mechanic is saying that I'll need to at least keep 1/8 tank of fuel else the truck will suck air with the FASS? Is that right or is there something else that needs to be done - would hate to run out of diesel on a long empty stretch in that I'm use to the idiot lite coming on at 1/8 tank to remind me? Thanks, DD
Old 12-05-2008, 11:51 PM
rebal's Avatar
I have a fass o my 01 and have run it down low with out issues But I try not to.because the vp44 needs cool fuel so i try to keep it no lower then 1/4
Old 12-06-2008, 12:13 AM
AggieJustin's Avatar
Did they change the pickup in the tank? If not, then it should work like it did before. If they changed out the in-tank pickup and did a Draw Straw, then they may have cut it a bit short so that it's not right on the bottom of the tank, which would cause issues with a low fuel level while in motion.
Old 12-07-2008, 01:36 PM
dodgerdog's Avatar
hopefully they did nothing to the in tank setup - no drawstraw. I'll ask to be sure. The mechanic did tell me that I'll need to be sure to keep tank 1/4 full and more else risk chance of sucking air - which is what I though the FASS was designed to alleviate as in "fuel air separator system"? If this is true - that I need to keep 1/4 tank of more, is there an another modification needed in tank to make sure the FASS doesn't suck air? Thanks, DD
Old 12-07-2008, 03:43 PM
Jason_K's Avatar
x2, never modified anything in the tank of my 01 and never had a problem running the tank low
saddlemaker
11-13-2006 12:44 PM
jd03ctd
19
11-14-2003 09:00 PM
thumbs
09-05-2003 09:30 AM
turbotoys
03-31-2003 01:12 AM
Quick Reply: FASS - need to keep at least 1/8 tank
