FASS or Big Brakes needed?
Old 10-27-2006, 02:05 AM
akhunter68's Avatar
Got an '06 CTD 2500 w/ Mega Cab and 6" suspension lift w/ 35" tires. I've added gauges, cold air intake, 65hp Quadzilla chip, and Banks Moster Dual exhaust and High Ram. Do I need a FASS Pump and/or Big Brakes. If so, which ones and why? HP? Stopping power? I drive in Alaska and frequent winter conditions.
Thanks,
Phil
Old 10-27-2006, 10:54 AM
Diesel-Dan's Avatar
What is your plans for the truck? HP wise? AND mod wise? On your year truck, you have the option of running a CP3.4 or mod your current CP3. After you do this, it is suggest to run about 45 PSI to the inlet of the new pump. This will have a bearing on what pump to choose for your set up.
Old 10-27-2006, 03:01 PM
iflych52's Avatar
Pacbrake really warms up the engine in the mornings and slows you down very nice. Love mine
Old 10-27-2006, 07:37 PM
rustyshakelford's Avatar
since you got the 06, take it to the dealer and get the ehaust brake. if not i think its always a good idea to remember your brakes when you get larger wheels and tires. the added weight makes quite a difference. the factory brakes are not to bad either though
brett
Old 10-27-2006, 10:57 PM
sid325's Avatar
What companies make aftermarket rotors or up-graded brake kits for our trucks?
wildcargo
11-29-2005 04:20 AM
Buckshotmckee
05-23-2005 12:08 AM
2wheelsup
05-17-2005 10:45 PM
Flatty
04-25-2005 12:49 PM
ralphie
04-21-2005 12:51 PM
Quick Reply: FASS or Big Brakes needed?
