Factory Oil filter.... and BRUISES!!!
Old 07-13-2007, 09:15 AM
Roperteacher's Avatar
I think dodge onwners manuals are hypocritical!!! LOLOL It took me about 20 minutes under the truck to get the origional oil filter off from the factory!!! Had to use a wrap wrench and I sure as heck did not drain the oil before getting it lose just in case... So milimeter by milimeter I got it lose and changed the oil.... Then the NERVE of the owners manual to state NOT to OVERTIGHTEN as it may cause damage.... Gees!!! They need to take some of thisr own medicine. I have wonderful bruises all over my hands this morning and a finger 2x bigger than it was before I started!
Old 07-13-2007, 09:42 AM
belgianmagic's Avatar
they didn't overtighten it ...when they set up the motor and before install they spray the whole thing (including oil filter) with clear coat...in other words "THEY PAINT SEAL IT ON ...LOL better to let them do the first I'll do the rest !!
Old 07-13-2007, 09:57 AM
dodgezilla04's Avatar
yep, the 1st one isnt really fun.
Old 07-13-2007, 10:25 AM
mlmiller's Avatar
losen while the engine is cold.this helps because it was installed when it was cold.the heat expands the seal making it hard to remove.
Old 07-13-2007, 10:35 AM
cummins also does not lube the oring when installing from the factory. that and the clear coat, really glues that baby on.
Old 07-13-2007, 10:38 AM
yellowhemi's Avatar
Did my 1st change last week. Man was that clear coat hard to break loose . Went to a buddies shop to do it. To make it worse, the lift couldn't even pick the truck up!
Old 07-13-2007, 12:31 PM
Thanks! I was wondering what that Gritty crud was on the outside of the filter!!!! Had no idea about the clear coat. Why would they clearcoat it??? FOr "Looks"??? My oil drain plug was NOT as tight as I would have liked it either... It's always good to goover the truck when new!!
PML cover is installed now too!!
Old 07-13-2007, 12:45 PM
Pooter's Avatar
Underneath the truck?
Only time I get under is to drain the oil, and put the plug back in.
I pull the filter from the top, pull the air intake tube/piping, then its easy to get to from the top. Id never do it from the bottom and risk a face/ear full of oil
Old 07-13-2007, 12:49 PM
oneslowyfz's Avatar
i am changing mine right now for the first time and i stil cannot get it off, i am using strap wrench, and still not coming off, is there something else i can use to try and get this bastard off? thanks in adv,
Old 07-13-2007, 01:04 PM
LongRanger's Avatar
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
This is what it took to get my filter off for the first time. I tried a cap type and strap typed, didn't budge. Had to go to Sears and get one of these. KD tools also makes this type of wrench.
After you get the first one off oil changes are easy.
Old 07-13-2007, 01:08 PM
LongRanger's Avatar
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Hope the link works this time.
yellowhemi's Avatar
Got mine off through the right wheel well. Pull the wheel liner back and there it is.
Old 07-13-2007, 05:14 PM
Danderson's Avatar
Thumbs up Killer oil change wrench.
Originally Posted by LongRanger
Wow.that's definitely THE TOOL!
Old 07-13-2007, 05:19 PM
cdru's Avatar
I use the same tool as LongRanger and had no problem getting the first filter off at all. Easy to get to from the bottom. I bought my wrench at the local Arctic Cat dealer to remove the filter on our 4-stroke snowmobile. Our cost was MUCH higher. The best filter wrench I have ever had.
Old 07-13-2007, 05:24 PM
Swamp_Donkey's Avatar
oneslowyfz,
Try going the other way! Sorry, I am not much help.
Quick Reply: Factory Oil filter.... and BRUISES!!!
