ez box upgrade?
Old Jul 27, 2006 | 03:27 PM
dieselbeef's Avatar
Muted User
ez box upgrade?
ive got an ez box but its a not much of an upgrade although it is noticeable. what i am wondering is what is avail without the monitors and guages cuz i already got the truck setup with a full autometer lineup. pyro/boost/fuel press/trans temp/oil press and temp. also got 275 injectors/open pipe/airaid filter system. whats a good box to give me a little more than the edge without a lotta grief installing it. truck runs awesome now but....ya know
__________________
Old Jul 27, 2006 | 03:51 PM
lsgibb's Avatar
There are several boxes on the market but none are easier to install than the Smarty since it's plug n play
Old Jul 27, 2006 | 04:30 PM
Docismyname's Avatar
dieselbeef, have you put a turnbuckle on your waste gate? This will add some zoom I got 12 pounds of extra boost
Old Jul 27, 2006 | 04:48 PM
blackdiesel's Avatar
Registered
he has an 02, no turnbuckle. It has a elbow that he can change out, one came with his ez. The next box is a wire tap box, a comp, or a tst to stack with your with your ez because it just adds fuel, no timing that would be your best bet, I think. YOUR TRANNY"s not going to like you though
Old Jul 31, 2006 | 03:21 PM
dieselbeef's Avatar
Muted User
my turbo's got the welded elbow. nothing to do with that setup. been wondering bout the tranny too...dont need that grief. maybe i oughtta leave it alone for awhile....nah!
Old Jul 31, 2006 | 08:06 PM
Marine's Avatar
Veteran: Marine Corp
If you pull anything, the Comp with that setup will be a little warm in the EGT's. The EZ is perfect without getting a bigger turbo. I wish I had my EZ back just for pulling.
Old Jul 31, 2006 | 08:20 PM
scottsjeeprolet's Avatar
Just for yuks try unpluggin the Map from the block.
You'll love the seat of the pants power from the take off.
I think that the Comp would be for you. Just turn it off when towing, I tow with mine on 3x5.
Old Jul 31, 2006 | 08:23 PM
Marine's Avatar
I tried turning it off- EGT's were hotter than having it on 1x1.
What are you towing on 3x5? I also have a 91% TC.
Old Jul 31, 2006 | 08:32 PM
Charlie8301's Avatar
Cant use the boost elbow on an '02.
Turnbuckle or J-Hook will work
http://www.tstproducts.com/index.asp...PROD&ProdID=63
Randy
Old Jul 31, 2006 | 09:31 PM
Registered
Randy
my bad, I see he has a hy not a hx
Old Jul 31, 2006 | 09:39 PM
i am towing scottsjeeprolet. CJ-7 with chevrolet 350 in it, hence the name.
Cruise on 70.
Your TC might have something to do with it.
Old Jul 31, 2006 | 09:46 PM
dieselbeef, have you tried a turnbuckel or j-hook? If not I would suggest that you try one of them.
Old Jul 31, 2006 | 10:13 PM
Marine's Avatar
Cruise on 70.
There is no doubt my TC has something to do with it. I have to go back to the EZ, or get a bigger turbo. I would like a bigger turbo, of course!
Old Aug 6, 2006 | 09:57 AM
dieselbeef's Avatar
Muted User
who can tell me what the j hook does for my boost
Old Aug 6, 2006 | 10:56 AM
It will hold the wastgate shut longer allowing higher boost numbers
Randy
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
