Exhaust Leak with DPPI Exhaust
Old 12-19-2004, 01:31 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
Yesterday I noticed an exhaust leak where the downpipe meets the turbo elbow from my DPPI exhaust. I thought maybe the clamp was just loose, but it was still plenty tight when I tried to tighten it up.
Has anyone else had an exhaust leak at this location with the DPPI exhaust? If so, how did you fix it?
Old 12-20-2004, 07:55 AM
Hoss's Avatar
No ideas??
Old 12-20-2004, 10:34 AM
Mark Craig's Avatar
Hoss,
You'll need to remove the pipe enough to see where the leak is occurring. It should leave a real obvious trail as to the exact location of the leak. You might have a burr or gouge on the inside of the pipe etc that might be causing it as we haven't ever had a customer call with a leak at the turbo before.
Mark @ DPPI
Old 12-20-2004, 11:13 AM
Hoss's Avatar
I can see where it's leaking from. It's leaking at the joint in the clamp (where you would tighten it). I just can't figure out how to fix it.
My truck is an early '03. I thought I read on here somewhere that the early '03 trucks had a 4" outlet instead of the 3.5" outlet that the later '03 trucks have. I know your system is designed for the 3.5" outlet. I'm wondering if I don't have the 4" outlet and as a result it's not sealing up good. That would explain why it's only coming out at the joint (where there is no clamp to keep the exhaust from escaping). I noticed when I installed the system that the end of the downpipe appeared to be smaller than my stock one, but I figured I was wrong.
Lightman
11-30-2004 03:05 AM
Hoss
22
06-09-2004 07:13 AM
Hoss
34
05-25-2004 03:18 PM
mjbarr99
18
04-06-2004 04:59 PM
Mark Craig
07-22-2003 01:10 AM
Quick Reply: Exhaust Leak with DPPI Exhaust
