Eratic engine temp
Old 02-02-2010, 06:34 PM
oldblu's Avatar
Eratic engine temp
Hey,
i'll be driving a long the hwy and notice my truck is getting cold cause the heater quit putting out heat, then look down at my temp gauge and its going crazy. It will go from 190 or so to pegged all at once any ideas guys. Then shut the heater off and it is fine in a bit thanks
Old 02-02-2010, 06:39 PM
tryNto's Avatar
low on coolant, bad thermostat... check the level when cold at the radiator, may need a new cap...
Old 02-02-2010, 08:08 PM
johndeere01's Avatar
mine would climb almost to the red fast an then drop to below 210 an then back up to the red really fast when my water pump went.
Old 02-05-2010, 05:12 PM
jfdid's Avatar
Make sure to check your rad cap(just replace it) and make sure the overflow tube is connected without leaks, and clear of debris. I had a similar issue and the tube wasn't completely connected, it ended up leaking coolant out when the truck would warm up, then would suck in air instead of coolant. Such is life.
Let us know what you found.
titan1
54
04-12-2009 10:40 AM
ingramg
02-08-2009 07:26 PM
MR HYDROSEED
01-19-2008 11:27 AM
dctoner
04-09-2004 08:49 AM
bigbaddiesel
03-18-2003 02:37 AM
Quick Reply: Eratic engine temp
