Electric Fuel Pump?
Holley blue pumps are great. I have one in my 81 chevy truck with built 355 running low 13's in the quarter mile. I believe you would put this between the tank and the lift pump, and just upgrade to a piston pump while your there. This will not make the lift pump work as hard and will have a constant steady fuel supply. i know wannadiesel has one and i believe a few others have them too.
The only benefit of an electric pump is that you don't have to manually prime the air out of the fuel lines after you change the fuel filter.
Read up on the piston pump. It'll cost about $200 to switch over, but that should be the last time you buy a lift pump.
No Holley Blue on my truck, I have a Walbro 392. According to the flow curve it's pumping about 65 GPH at the pressure I'm running. It's sold as a 255 lph pump.
If you want good fuel pressure at the VE, you need a high volume, high pressure pump and you need to regulate it with a bypass regulator AFTER the fuel filter(s). A Holley Blue fulfills none of these conditions.
What pump is going to last longer
1. designed to operate at 65+psi but actually operating at 20-psi?
or
2. designed to operate at 14psi and operating at 14psi?
i'll take option 1.
I was just told the Holley is supposed to be 110gph @14psi free flow and 88gph @9psi. I just talked to guy who is running a Holley and he says he likes it. I am just wondering what I should run.
Wannadiesel, are you running the Walbro instead of a mechanical LP?
Wannadiesel has both mechanical and electric, but not in series, in parallel.
So what I'm reading guys are having an electric pump, pick up from tank and supply to the mechanical pump? And if thats the case then do you have the bypass reg before of after the the mechanical pump? And also if you are supplying the pressure to the mechanical pump then is it nesseasry to change over to the p pump lift pump, or will the stock lift pump work, if using the electric supply pump?
Jusitn
Jusitn
No you don't really want to feed one pump with another pump, especially if you have the stock diaphram lift pump.
I you really want an electric lift pump than this is what you would want to do:
https://www.dieseltruckresource.com/...el+pump+bypass
But really a piston LP is probably the best option for reliability and flow. Unless you're shooting for some big HP with a 14mm HR.
Well what I'm looking at doing is a hefty fuel system for a pulling truck. I may not even go this route, I just want to know what people are actually doing for heavy fuel flow. The truck is getting probably one large charger (HX50 for now because I have it), and I don't know I may even go with a P-Pump.
