Egts
Old 01-18-2008, 10:47 AM
12valvetom's Avatar
Egts
I was plowing the other night and my egts never went over 1000* but my concern is i have no plate and no afc and everyone says without them doing anything besides driving it will get hot??? I had 1000lbs of salt in the bed with an 8ft western plow going up some long hills to get to where i had to plow also.
Old 01-18-2008, 06:57 PM
schaef_12's Avatar
where is your pyrometer probe? If it is after the turbo in the exhaust elbo then 1000* is all you want to see.
Old 01-19-2008, 12:01 AM
joshua smith's Avatar
i dont think ive seen that number since i first got my truck.
Old 01-19-2008, 12:11 AM
spooling's Avatar
imo plowing with 1000lbs isn't much load on the engine. I never have to worry about high egts unless i'm towing 10,000lbs+ up steep inclines
Old 01-19-2008, 01:20 AM
thewished's Avatar
and you said plowing... Usually means its cold outside because there is snow... Just something to think about. When I have my cold fronts in my cruising temp is around 150* higher then when I have airflow over my intercooler.
Old 01-19-2008, 03:46 PM
12valvetom's Avatar
My probe is before the turbo but the plow blocks the air going to the engine trust me i never hooked up my trans gauge so it sits under and it never reads but with the plow on driving down the road or sitting still its at 180* But i have no afc or plate and everyone says egts get way out of control and no matter how hard i got on it they barely got over 1000*
Old 01-19-2008, 03:47 PM
12valvetom's Avatar
Plus the plow blocking the air flow ,its like pushing a wall down the road
NOTSTK
08-09-2003 09:10 AM
doug
103
07-02-2003 02:27 PM
thecatsfan
16
06-20-2003 10:36 AM
cowpie
01-29-2003 09:08 PM
1ST GEN.
10-19-2002 08:45 AM
Quick Reply: Egts
