EGT's sound right?
Old Nov 13, 2002 | 03:13 PM
BigBlue's Avatar
EGT's sound right?
My EGT's seem low. Granted, the air is about 70* (+-5*) and I have a BHAF with a 4" straight pipe, but they still seem low. Sitting at a stop light, they hover around 410. Accelerating normally they get up to about 600. When I cruise at 55mph with OD off, they read about 500. Full throttle accleration all the way up to 80mph, they never read above 670. This is with the comp on 1x5. The pyro is centered directly behind the exhaust turbine housing as close as I can get it to it and it is right in the center of the exhaust flow (measured diameter of pipe, took half of that, put tip of pyro about 1/8"-1/4" below so whole tip is in stream). I have a post gauge (trying to figure out a dual setup with the Dakota's) so they will be lower than pre but this seems really low. Do these numbers seem right? The probe is brand new from Dakota. But even with my old Autometer gauges, it read that low.
Old Nov 13, 2002 | 03:46 PM
KatDiesel's Avatar
Re:EGT's sound right?
Post turbo users generally add 300 degrees to &quot;guess&quot; at the pre turbo tempertures. Thats a rule of thumb however that is not true in all cases it can vary by as much as 600 degrees.<br><br>With the COMP on 1x5 (did you retap the wire?) its jsut an EZ mode type of upgrade, with stock injectors 970 doesn't sound unreasonable. I don't get much over 1050 pre on my BD IV injectors only (120hp), but I have a few air upgrades.
Old Nov 13, 2002 | 04:02 PM
BigBlue's Avatar
Pump wire is hooked back up. EGT's don't change though really on any setting.
Old Nov 13, 2002 | 07:05 PM
chuck3's Avatar
Blue thats about what mine reads.
Old Nov 13, 2002 | 07:49 PM
danlit's Avatar
400 idle in gear,500-800= 55-75mph hwy, foot to the floor it jumps to 1200+ real quick.<br> Danny
Old Nov 13, 2002 | 07:54 PM
admin's Avatar
[quote author=BigBlue link=board=4;threadid=7000;start=0#66367 date=1037224959]<br>Pump wire is hooked back up. [/quote]<br><br>Your tranny isn't modified, is it?
Old Nov 13, 2002 | 10:52 PM
DarrellB's Avatar
With a set of 275 hp injectors and a Power Max 2 and EZ I have to work real hard to get mine above 1200* pre turbo. That's with a BHAF and a strait pipe, and pulling about 8k up a 6% grade at 70mph. 8)<br><br>Darrell
Old Nov 14, 2002 | 10:54 AM
BigBlue's Avatar
Bone stock Jack. Just can't run it above level 2. Maybe an occasional level 3 if I am locked up.
hulmule
Mar 10, 2010 10:42 AM
jmccart
13
May 5, 2008 04:17 PM
00Dog
Sep 19, 2006 05:21 AM
Junk Yard Dog
Mar 15, 2004 10:47 PM
blackholehunter
Apr 14, 2003 08:55 AM
