EGT TC Install location
Old May 8, 2006 | 03:42 PM
TonyB's Avatar
So, I am installing most (if not all) gauges this weekend.
I have the boost bolt, banjo bolt, and mass diesel trans line on order and are due late this week. I went with the autometer NV series. I will be switching pressure between oil, boost, and fuel. Switching temp between Water, trans, and diff. Only the pyro will be dedicated.
Anyway, I want the pyro pre-turbo, in the exhaust manifold. I've heard some installing it near the turbo flange, and others near cylinder #5. What's the consensus? FYI...I will be going through the extra effort of removing the manifold, just to ensure I don't get any shavings into the turbo, so placement from an install perspective is not an issue.
TIA
Tony
Old May 11, 2006 | 03:04 PM
TonyB's Avatar
BTT
Any opinions, for one way or the other?????
TIA
Tony
Old May 11, 2006 | 03:06 PM
8mpg's Avatar
I installed mine today between 3-4. Edge recommended that spot.
Old May 11, 2006 | 03:45 PM
PEAKSTRYDE's Avatar
PROBABLY NOT WORTH YOUR TIME^^^^^^^^^^they're small little shavings
I let my truck idle when I drilled the manifold
BADBADBADBADBADIDEA
once I went thru the HOT shaving splattered me in the face
BIGBIG NO NO NO NO NO NO
DITTO ME 2
Old May 11, 2006 | 05:57 PM
staarma's Avatar
I'll post this pic for you to see where Edge recommends the thermocouple to be placed right out of their manual. This does two things for you. The first is it gives you an idea of how hundreds have done it including me and the other guys that have responded to your thread and the second is the people who think this is wrong and it should be on the rear cylinders, for reasons they have not given good understanding of yet, will post other pics of locations for you to choose. Good luck.
Old May 12, 2006 | 01:00 PM
TonyB's Avatar
Thanks for taking the time to reply! I really appreciate the input, and will be installing the TC into the same location.
Tony
59FORD
Apr 7, 2006 12:28 AM
lucey
Aug 1, 2004 09:59 AM
cquestad
Mar 26, 2004 06:40 PM
cquestad
Mar 4, 2004 02:26 PM
Drafter
Apr 16, 2003 10:58 AM
