Edge chip worth it or not
Old 07-13-2009, 10:08 PM
rams2500's Avatar
Being a rookie when it comes to chips I am leaning on buying the Edge Juice with attitude but have read a lot of mixed opinions about the product. Other than an intake, 4" exhaust, and fuel pressure gauge I'm stock. Looking to bump up some power but keep it real. As a farm truck I don't want to get carried away mainly because I rebuilt the rearend at 70,000 and the auto trans at 90,000 being bone stock. I appreciate any advise and opinions. Thanks
Old 07-13-2009, 10:23 PM
DodgenIt's Avatar
If you go with the juice/attitude, I would strongly recommend a lift pump upgrade. Airdog or FASS. Also with the power j/a can deliever, that trans might not hold up long on higher setting then 2 unless your babyin it.. which kinda takes the fun out of it haha.
Torque converter and valve body would put ya in a pretty good spot for the trans though. Billet input even better. Still might go a little easy though.
If you like what you see from Edge, check out an EZ or comp box.
The EZ would be the best for a little extra power with your stock parts.
I ran my EZ with only intake and 4'' exhaust for 14 months just fine.. before I couldnt take the power bug on my back and started upgrading it all haha.
Hope this helps.
Ian
gergthegreat
12-30-2008 09:19 PM
bansh-eman
01-27-2008 02:48 AM
Elk_Hunter
10-24-2006 03:17 PM
cowdude
02-19-2003 06:20 PM
Quick Reply: Edge chip worth it or not
