Is it easy to change FCA valve?
Old 05-21-2008, 04:46 PM
sallyman1's Avatar
As you know i have problems with my truck. dealer said its from edge level 1 being on ALL the time. I have a Fuel rail sensor problem and a fuel control valve issue. my truck idles at 27,000 psi rail pressure. sounds like a hammering old gen 2 dodge. Would edge cause these 2 things? i always drive on level 1? also would the FCA be part of why i have a high egt problem?
Anywyas the rail sensor i can change myself in 2 seconds but what about the FCA valve on the CP3 pump? would you have to remove pump to do it?
Old 05-21-2008, 04:54 PM
Rpainter's Avatar
no need to pull pump three hex screws and a wire harness and the fca will wiggle out.
Old 05-21-2008, 04:57 PM
sallyman1's Avatar
thanks. i owe u 1
Old 05-21-2008, 07:09 PM
03 ant a hemi's Avatar
How did you get your rail pressure readings?
The Edge should not have caused this problem.
Idleing at 27,000psi sounds like a bad FCA and or Pressures gauge as you have indicated.
But this will mean your injectors will more then likely be on their way out if you drove for any amount of time like this. Idle should be around 5000psi.
Good luck I hope you get your problem fixed.
Cheers
Old 05-21-2008, 08:23 PM
sallyman1's Avatar
I have a quadzilla RP gauge. But my dealer must have had their scanner hooked up. they told me it was this high at idle.
Old 05-22-2008, 06:50 AM
sallyman1's Avatar
anyways im changing the sensor myself. does the rail sensor have a normal 1/8 PT on it? do you just screw it in or do u use teflon tape on threads. reason i ask is i know about old systems but not sure if teflon tape can stand up to 25,000 psi in the rail? or does sensor come with red paste on threads already?Whats the torque on it snug or about 10 lbs ft.
Old 05-22-2008, 06:54 AM
DTR's 'Go to Guy'
vzdude's Avatar
TORQUE - FUEL SYSTEM - DIESEL ENGINE
DESCRIPTION N-m Ft. Lbs. In. Lbs.
Accelerator Pedal Bracket -to-Cylinder Head Mounting 432 32
Accelerator Pedal Position Sensor Bracket-to-Battery Tray Bolts 3 - 27
Crankshaft Position Sensor 9 80
Camshaft Position Sensor 9 - 80
Engine Coolant Temperature Sensor 18 13 160
Rear Engine Lift Bracket Bolts 77 56 -
Fuel Connector Nut at Cylinder Head 50 37 -
Fuel Filler Hose Clamp at Tank 3 - 27
Fuel Filler Housing-to-Body Screws 2 - 17
Fuel Filter Lid 34 25 -
Fuel Filter Drain Valve Screws 1.5 - 14
Fuel Heater Element Screws 1.5 - 14
Fuel Pump Module Lock Ring 54 40 -
Fuel Line Banjo Fitting Bolts 24 18 -
Fuel Line Fittings (High-Pressure - Pump to Rail) 37 27 -
Fuel Line Fittings (High-Pressure - Cylinder head to Rail) 30 22 -
Bracket Over #6 Fuel Line (Bolts) 43 32 -
Fuel Injector Solenoid Nuts 1.25 - 11
Fuel Injection Pump-to-Gear Shaft Nut 105 77 -
Fuel Injection Pump Mounting Nuts 24 18 -
Fuel Line Support Clamps (High-Pressure) 24 18 -
Fuel Pressure Sensor 70 52 -
Fuel Pressure Limiting Valve (Banjo Bolt) 24 18 -
Fuel Pressure Limiting Valve (In Fuel Rail) 70 52 -
Fuel Rail Mounting Bolts 24 18 212
Fuel Tank Mounting Straps 41 30 -
Map Sensor Mounting Screws 1 - 9
ECM-to-Engine Bracket Mounting Bolts 24 18 -
ECM Electrical Harness Connector 3 - 27
Water-In-Fuel Sensor 4.5 - 39
Old 05-22-2008, 06:57 AM
DTR's 'Go to Guy'
vzdude's Avatar
1. Replace the EFC as follows, if the high pressure fuel pump is discharging the correct
amount of fuel.
a. Remove the cap screws (3).
b. Using a (Clockwise/Counterclockwise) twisting motion, remove the EFC.
c. Using a (Clockwise/Counterclockwise) twisting motion, install the EFC.
d. Install the cap screws (3). Torque the cap screws in two steps. Step 1 - Torque all
cap screws to 3 N·m (27 in. lbs.). Step 2 - Torque all cap screws to 7 N·m (62 in.
lbs.).
e. Start the engine to remove air from the fuel system. >> Go to Step #2.
2. Repair Complete. - Perform Powertrain Verification Test VER - 1 (Diesel). Refer to 8 -
Electrical/Electronic Control Modules/Engine Control Module - Diagnosis And Testing.
Old 05-22-2008, 03:10 PM
Rpainter's Avatar
i was told teflon tape on anything fuel related is a big no no if a tiny piece comes loose it can kill injectors or cp3
Old 05-22-2008, 04:16 PM
sallyman1's Avatar
so then what to use? the specs above dont give torque for RAIL SENSOR? are they in NM or Ft lbs the first set of numbers?
Old 05-22-2008, 05:44 PM
Rpainter's Avatar
IF THEY ARE NPT THREADS THE THREAD COUNT IS CLOSDE ENOUGH NOT TO NEED ANY SEALANT
Old 05-22-2008, 06:36 PM
sallyman1's Avatar
fuel pressure sensor spec says 70/52. is that 52 in lbs or 52 NM?FCA 3 bolts get torqued to what it dont say either?
also what socket needed for FCA removal? t27 or t25 torx? female or male?
Old 05-23-2008, 09:27 AM
staarma's Avatar
No idea on torque specs.
Juice doesn't adjust rail pressure on 04.5-07 trucks. The only thing you should have had hooked to that sensor should have been from the Commander to just read rail pressure. FCA's go bad as well as rail sensors. Just a fact even on stock trucks. Good luck.
Old 05-23-2008, 09:47 AM
DTR's 'Go to Guy'
vzdude's Avatar
It is clearly listed in my previous post. But I guess I'll spell it out........
The Fuel Pressure Sensor Torque is 52 Ft. Lbs.
Old 05-23-2008, 08:47 PM
sallyman1's Avatar
thanks. only Quad rail gauge hooked up to rail sensor yes. dealer told me my edge messed everything up. and yes i have Hot unlock setting #6 and that does increase rail pressure.
Quick Reply: Is it easy to change FCA valve?
