Dyno #s
Old 08-29-2009, 04:28 PM
justin allan's Avatar
Dyno #s
well went to the dyno today to see if I could do alittle better that what is says in my sig and it was alot worse. 440 hp and 930 ftlbs. got 45lbs of boost so load was ok. thats what I see on the street. I used to see 53 but now only 45, not sure why that is. But there is something wrong with my truck and don't know what it could be?? dose anyone have a clue??
Old 08-29-2009, 07:48 PM
farmboykjb5.9's Avatar
Heck i would've figured you'd hit 600 hp easy.
Old 08-29-2009, 10:07 PM
rip 112's Avatar
Yea something doesn't seem right...you should def be WELL over 500hp
Old 08-29-2009, 10:37 PM
Spooler's Avatar
What was the RP on the run?????
Old 08-30-2009, 02:01 PM
I am not sure what the rail preasure is cuz I threw my quad gauge away it was taking out my RP sencer out. I no with out the mp8 my rail preasure is about 25k looking at the scanner.
For all the stuff I have done to the truck and tryed different things I can't seem to get anything to work I am ready to give up on this truck and get an 06 megga if I can find one.
Old 08-31-2009, 12:42 AM
ScienceOfSpeed's Avatar
what kind of dyno was it run on and did the dyno have a brake?
Old 08-31-2009, 06:51 AM
Brian Lent's Avatar
Something is definatley up. Do you have a video of the run? You ststed that your boost used to be higher. So it is not fueling as hard or you have a boost leak somewhere. I had noticed my truck loosing power once and it was from manifold gasket leaks. Couldn't hear them or see them because it was in the rear. I just decided to take the turbo off and have a look and it helped dramatically. It can be something that small to mess with boost. Check for leaks, then maybe reload the smarty, have injectors checked out. Good Luck, you will find it.
Old 08-31-2009, 08:59 AM
I don't have a video of the run. Yea I will have to check out to see if I have a boost leak, And I thought I would try to reaload the smarty I will have to do some digging and figure out what is going on. Thanks
Old 08-31-2009, 11:46 AM
Duallydog's Avatar
Have you replaced the relief valve?
Old 08-31-2009, 02:28 PM
Never have.
Old 08-31-2009, 05:47 PM
Duallydog's Avatar
I bet you its popping off.
Old 08-31-2009, 10:02 PM
mpracehemi's Avatar
Anytime a person is running a pressure box or anything that increase rp, the valve should be capped, it's a one time relief and then needs to replace, ($$$).
Old 09-01-2009, 10:52 AM
what do you do to cap the rail?
Old 09-01-2009, 12:26 PM
mpracehemi's Avatar
Do you know where the press. valve is?? Find the line that goes back to the stock fuel filt. (acts as the return), now trace it back to the rail. The bolt that holds the fuel line can be pulled out, tapped (1/8'', same as the egt probe) then install a set screw/plug with loc tite and let it set up. That way in the future, it can be undone and still didn't cost hardly nothin'.
Old 09-01-2009, 12:30 PM
rip 112's Avatar
Photo courtesy of D45
Quick Reply: Dyno #s
