Dust / Lint Guage Cluster
Old 07-11-2005, 11:05 AM
SilverRam01's Avatar
Hey gang;
Can anyone give me any insight as to the best way to resolve this issue? I just purchased this truck a week ago, and uppon a throural cleanup of the truck, have noticed a small amount of lint / dust behind the plastic lens, just before the insturment panel.
Do I have to disassemble the entire dashboard in order to get this cleaned out? Any ideas ? How in the world did dirt / dust get behind the lens in the first place?
Old 07-11-2005, 11:12 AM
smokindog's Avatar
Yup, the trim piece pops right off by hand, but then you'll need a screwdriver to remove the lens over the gauges. Not a big deal, should only take you about 15 minutes.
Old 07-11-2005, 12:06 PM
Awesome! I was hoping this would be a minor issue. Thanks Dog!!
Just hope I dont break anything in the process. It seems that things that are supposed to "pop-off" generally "break-off" when I attempt this sort of project. LOL.
Thanks again.....any advice on "popping-off" the trim piece would be welcomed!
Old 07-11-2005, 01:59 PM
berner's Avatar
A word of warning. The lense is very fragile. I cracked mine while cleaning it. I was holding it with one hand and wiping with the other. Best to lay it down on a soft towel. Be careful when cleaning around the pin on the speedo. They break really easy too.
Old 07-11-2005, 04:19 PM
Thanks guys! Got er done! Felt like I was performing brain surgery cleaning / dusting around those gauges. Looks much better. Previous owner must have used wd-40 or something similar to clean that plastic lense, it has a "glazed" somewhat pitted look to it....but still looks much better having removed all the lint build up laying just ahead of the gauges.
Much abliged.
Old 07-11-2005, 04:30 PM
crobtex's Avatar
Mine has the pitted and scratched look too, and it's never had anything but Windex and water.
Old 07-11-2005, 04:44 PM
Mopar1973man's Avatar
Re: Dust / Lint Guage Cluster
Originally posted by SilverRam01
Hey gang;
The dust and lint come from the trip button... There is enough gap between the **** and the lens that you'll be amazed at what will fall through...
Old 07-11-2005, 05:23 PM
quantrill88's Avatar
had the same problem on my 2000. solved it by pulling the lense and putting a grommet around the hole, no more lint.
Old 07-11-2005, 07:54 PM
infidel's Avatar
Can't say enough good things about Meguiar's Mirror Glaze Clear Plastic Cleaner.
Takes any scratches and haze right out of clear plastic.
http://www.meguiars.com/estore/produ...eaner&sku=M-17
Old 07-11-2005, 08:17 PM
BoostdCTD's Avatar
Excellent, this is one of the last things I want to do to my truck to have it finally all cleaned up.
I've used MAAS polish before on plastic and it also did a great job getting those scratches out.
Old 07-11-2005, 10:19 PM
ccmckee's Avatar
It's the ammonia in the windex that causes the pitting.It dries the plastic out, you should just use a mild soap and water mixture or a dust rag, one of those rags that is coated with something to pick up dust. It's the same if you have window tint nothing with ammonia in it.
Old 07-11-2005, 10:43 PM
BoostdCTD's Avatar
That's nice I just cleaned mine with Windex....
Old 07-12-2005, 09:21 AM
crobtex's Avatar
Gotter Done!
Boy! Those little gage needles sure are touchy!
It's amazing how much crud builds up over six years. All I had to use was "non-ammonia" Windex and it done a pretty good job. Since the scratches are on the outside, I'll attack them when I get some Meguiar's Mirror Glaze Clear Plastic Cleaner.
Old 07-12-2005, 11:28 AM
MKELLY's Avatar
You may want to try compressed air in a can, the type you'd clean your key board off with
Old 07-12-2005, 11:30 AM
crobtex's Avatar
I wouldn't want to put too much air pressure on those little gage needles.
Quick Reply: Dust / Lint Guage Cluster
