drag link question
Old May 31, 2005 | 07:21 PM
HOdiesel80's Avatar
drag link question
Upon doing a suspension/steering inspection I found that my drag link may be loose. I cant move it from side to side but I can wiggle it back and forth (front of truck to back and vice-versa). And of course the O.E. fittings don't have grease certs. Is this normal? I've been noticing something funny in the front end after installing coil spacers. But I haven't replaced the track bar either yet, but it's next. The funny feeling is a thump or pop that I can feel in the steering wheel. Any insight to this guys? Thanks
Old Jun 4, 2005 | 07:21 PM
dezlsmkr's Avatar
My track bar went out. You could look under the truck and have someone wiggle the stearing wheel back and forth and watch it move up and down. I didnt replace the whole bar i used a LUKE'S Link and it worked pretty good. If you dont have alot of money that is a good way to go. If you do have the money there are places that offer aftermarket track bars that are awesome. I hope you dont ever have to experience the " death wobble" Oh god thats a fraky situation.
Old Jun 4, 2005 | 08:22 PM
rockwithjason's Avatar
Yeah death wobble sux. I only had it twice then an autozone track bar went on, lifetime warrenty you know!
Old Jun 4, 2005 | 11:24 PM
fschiola's Avatar
You can check all of the tie rod type ends by using a pair of water pump pliers and putting one jaw on the ball stud end and the other on the opposite side and squeeze together. Any movement means a worn joint.
bigragu
Jun 9, 2009 01:48 AM
sledneck1
Feb 7, 2007 01:57 PM
Totallyrad
Sep 11, 2006 05:28 AM
ob1kobi
Feb 17, 2005 10:14 PM
sennbj
Mar 16, 2003 11:11 AM
