how do you pressure test intercooler?
Old 04-19-2006, 11:49 AM
farmer13's Avatar
anybody know how you can hook up to the 3in. line going to the intercooler to pressure test it? It is a 98.5 24 valve cummins
thanks
Old 04-19-2006, 04:27 PM
volly818's Avatar
With some mechanical skill you could make a adapter from 3" pvc pipe and make a cap. Then drill the cap to fit a air chuck. Just make a cap without the hole for the other side. It wouldn't take much to make. Also fill out you sig. so we know auto, man. and all the goodies.
Old 04-19-2006, 05:08 PM
kipo's Avatar
i made an adapter for mine with a piece of 4" exhaust pipe (4-5" long); welded a 1/4" piece of metal for a cap with a 1/8" NPT weld fitting for guage, chuck, ect.; then found a piece of 4" Goodyear radiator hose or PVC rubber coupling; hose clamped them all together on the turbo inlet; then regulated 20 psi into that to pressure test the whole system. will post pics when i get a chance.
the dodge house was trying to find the source of a hesitation i have and their tool fits inside the turbo inlet and seals the system, but a phat shaft 62 has a bigger inlet than a hx 35.
Old 04-20-2006, 12:19 AM
J BODY's Avatar
I've got picts of mine in my gallery.
Old 04-20-2006, 09:25 PM
dodgezilla04's Avatar
plump it into my turbo, I can pump it up to 44 psi for you.
92smokin blacky
01-14-2010 09:23 AM
6Stix
02-13-2009 08:32 AM
mullishacrew
10-30-2008 09:29 PM
Valv
11-06-2007 06:01 PM
Quick Reply: how do you pressure test intercooler?
