What to do to install a 2 speed rearend
Old 02-24-2007, 12:49 PM
Valv's Avatar
I saw some truck that have a 2 speed selector on shifter. What's needed to install it on my truck ?
Do I have to replace the rearend ?
Old 02-24-2007, 01:40 PM
ckt_santiago's Avatar
Do I have to replace the rear end ?
They make two speed splitter boxes that actually go in between your trans and your rear end... 28% reduction on the low side or 28% overdrive your choice look em up on ebay you should find en somewhere... Easiest though would be to find a 2 1/2 ton rear end from a medium duty and retrofit it under your monster. Look at the bright side of that and you'll see that you get the advantage of 19.5 or 22.5 rims and higher load rated tires
Old 02-24-2007, 06:34 PM
clutch1's Avatar
Yeah its probably a overdrive unit. $2000 about, IIRC
Old 02-24-2007, 07:39 PM
Fueling around's Avatar
It is probably an E-brake control switch. That make mounting kits and it is popular with the hand shaker crowd.
Old 02-24-2007, 08:07 PM
Registered
blackdiesel's Avatar
yeah, my exhaust brake is setup to a two speed rear end switch on the shifter
Old 02-25-2007, 05:18 AM
Harold Swanson's Avatar
I have a 2spd aux trans on mine,its made by us gear and cost 2300 .
reaves11
05-22-2010 10:24 PM
Dynocon
07-14-2006 11:05 PM
sshelly
06-23-2003 11:34 PM
big b
11-10-2002 03:50 PM
ronster
11-01-2002 04:14 AM
Quick Reply: What to do to install a 2 speed rearend
