DiPricol Trans. Gauge Problem/Solved
Old May 9, 2007 | 06:55 PM
Triplggg's Avatar
Just put in the pillar triple pod from Diesel Manor.I had a problem with the
D-200-048 Full sweep Trans Temp Gauge.Gauge didn't work or did it have power.Both the Pyro and the boost gauges worked fine.
Buyers of the three gauge set-up (Pyro,Boost and Full Sweep Trans.) Have to move the molex connections.The Trans gauge part of the harness is wrong for this full sweep gauge.The wiring pigtail that comes with the gauge itself is right.I pulled the molex pins and placed them in the right order.Now everything works right.
Thanks for Diesel Manors help,and now they are aware of this problem so maybe others won't have to go through this.PM me if you need help.
Old May 10, 2007 | 03:56 PM
zuki_dan's Avatar
I had the same problem when i got mine from them, look at the pigtail that came with the gauges and rearrage the pins in the harness to match.
Lary Ellis (Top)
55
Nov 8, 2012 10:22 PM
jdwest
May 17, 2009 07:53 PM
C Minus
0
Mar 28, 2008 01:04 PM
Dodgezilla
May 18, 2003 06:00 AM
ROCKNRAM
Oct 21, 2002 12:24 AM
