Died last night on way home and wouldn't start
Old 09-08-2008, 02:51 PM
jaws136's Avatar
98.5, 24v, Auto, Raptor LP, Quad M3, 98k miles, driving home last night 10miles into 300 from cabin in AK truck just unexpectedly dies LP was showing 13 when bumping over while trying to bleed injectors. Normal pressure at cruise is 11/12. Is this a dead VP can fuel get to injectors from lp pressure with a failed vp? Only other thing i checked was fuses. I had to leave it.....i need help. Thanks in advance, any ideas?
Old 09-08-2008, 03:42 PM
j-fox's Avatar
Loosen as many injector lines as possible, crank it to see if equal fuel comes thru each line.
If not, the pump seized and is done.
These pumps will die with fuel pressure. much sooner without pressure.
Do you know anyone with a smarty? Borrow it and read codes.
Old 09-08-2008, 05:48 PM
Chris Taylor's Avatar
Mine did the same thing with no codes. Saving for a IP now....
Old 09-08-2008, 06:02 PM
jaws136's Avatar
on the phone now with anything diesel perf out of WA 999.99 ain't bad but better than 2255 from the local dealer. If you are interested http://cgi.ebay.com/ebaymotors/Dodge...hippingPayment
Old 09-08-2008, 09:48 PM
JSPulliam21's Avatar
Mine died over about two months dieing for no reason and strting when It felt like it. When it bit the bullet I could not get fuel to flow like it should out of the lines. With all lines cracked there should be a significant amount of fuel flow. If not, consider the pump DOA.
Old 09-09-2008, 09:15 PM
smokewagon's Avatar
was your tach still working when it died?
Old 09-09-2008, 09:17 PM
iker42's Avatar
ours has done the same a few times, hows your fuel level? try 5 gallons and some ether and it should come back.
Old 09-11-2008, 10:46 AM
jaws136's Avatar
Fuel was near full and all electronics work to lp and all. I'm betting it's the IP so waiting paitently for one to arrive.
mtkrauss
06-14-2010 06:48 PM
1STGENFARMBOY
04-05-2010 12:25 PM
jaws136
09-08-2008 05:19 PM
smokin92
10-28-2006 06:02 PM
Quick Reply: Died last night on way home and wouldn't start
