Day Time Running Lights
Old 08-20-2005, 02:14 PM
DUNERUNNER's Avatar
Angry Day Time Running Lights
I HAVE A 2001 2500 AND WOULD LIKE TO TURN THE DAY TIME RUNNING LIGHT'S OFF. ANYONE KNOW IF THERE IS A WAY TO DO THIS WITH OUT THE HELP OF A DEALER? I HAVE CONTACTED THE LOCAL DODGE DEALER AND THEY TOLD ME THAT THIS CAN NOT BE DONE. IS THIS TRUE? i KNOW THAT IT CAN BE DONE ON OTHER MAKES OF TRUCKS BUT NOT SURE ABOUT DODGE. ANY HELP WOULD BE GREAT.
Old 08-20-2005, 02:23 PM
J BODY's Avatar
They used to have a daytime running lamp module but i'm not sure if/when they stopped using that. if it still has one it will be on the fender well near the master cylinder. it's a little black box and if you unhook it you'll have to jump a couple of wires so that the high beam light in the dash will work correctly If not there may be a way to do it with the drb at the dealer.
ok I edited it back....I hate all caps hard to read.
Old 08-20-2005, 06:42 PM
infidel's Avatar
It's not that easy to disable them without effecting other circuits.
Way I did it for a friend was install a switch in the dash that jumped across the parking brake switch. No more daytime lights but the parking brake light will be lit when the switch is on. This will not effect your regular lights.
The way my friend was doing it before the dash switch was to push down the parking brake one click. Not enough to engage the brakes but enough to trip the pedal switch.
Old 08-23-2005, 10:43 AM
Korney's Avatar
I'm doing the same thing with my e brake and getting tired of people asking why my brake light is flashing. Thinking of just pulling the bulb out.
Old 08-23-2005, 11:04 PM
Lil Dog's Avatar
Just pull the plug on the DRL module and use a jumper to get the high beam indicator to work.
I don't know if the wire colors are the same, but I have a photo in my gallery of the DRL jumper for the High beam indicator. My box started making the headlights flicker and cut out on DRL during the day.. I tried getting a box from the wreckers, but they were hard to find. I just gave up and pulled the box out, and jumpered the high beam signal wire to the high beam indicator wire. Everything else works just fine.
J-eh
Old 08-24-2005, 11:48 AM
CTD NUT's Avatar
Why do you guys want to disable the DRL's? It has been proven time and again to be safer......you don't want to be safe?
BTW, please turn the CAPS off.....I agree with J BODY - it makes it annoying to read.
Old 08-24-2005, 02:02 PM
infidel's Avatar
The reason the guy gave me whose DLRs I disabled said he wanted to extend his bulb life.
To each his own.
Old 08-24-2005, 02:23 PM
CTD NUT's Avatar
I suppose bulb life is somewhat subjective.....it would be hard to say if running the high beams at half voltage affects bulb life at all - I certainly don't notice shortened bulb life. IMO, what isn't so subjective is the safety benfit.....bulbs are very inexpensive compared to lives......but you are right, I guess - to each his own.
Old 08-25-2005, 12:27 AM
01-24v's Avatar
Where they an option or something? My 2001 slt doesn't have them. Unless the previous owner turned them off some how. I just got it last week
Old 08-25-2005, 01:19 AM
KennyG's Avatar
Maybe the truck you have was originally built for Canada. All vehicles built for Canada have to have daytime driving lights....it's the law!! I personally think they are a great thing! There are times when the lights will get your attention before you'd otherwise notice the other vehicle. On the other hand I've never noticed a problem with having to replace bulbs at any more frequency. My bulbs are still original (5 1/2 yrs.)
Old 08-30-2005, 10:32 AM
rowilson's Avatar
I read an article a while back that talked about DRLs only being a benefit if you lived above the 45th parrallel or something to that effect. Most of the US and Canada don't need them and they are a marketing ploy to sell the modules. Here in the US where I was taught to drive we were told to "read" the oncoming traffic. So if you saw someone in the oncoming lane with their headlights on in the middle of the day there was either bad weather ahead of you (where they came from), they were up all night driving or they were drunk The DRLs for the most part are a nuisance and waste of time. Just another way of becoming numb and used to seeing lights on for no apparent reason. Just my and some others .02 worth.
Old 08-30-2005, 12:58 PM
CTD NUT's Avatar
A marketing ploy to sell DRL modules?!?! Uh, ok....I doubt any manufacturer is making a killing off of DRL modules - it certainly wasn't the manufacturers idea to have them!!.....I don't care what parallel you are from, you see vehicles sooner and from a greater distance when their headlights are on......most drivers don't seem to be capable of turning on their lights when visabilty drops for any reason so, the vehicle turns them on for you.....it is a simple as that.....if the object is brighter, it is easier to see.....why do you think motorcycles have been this way for years?
Old 08-30-2005, 02:15 PM
wildcargo's Avatar
I have a 2001 2500 and it has no day time running lights or thay were turned off by the previous owner. I would like to have them so I guess I will have to look see if thay aree disabled
Old 08-30-2005, 05:04 PM
phox_mulder's Avatar
They have never been OEM on Dodge pickups sold in the US.
Only those sold in Canada have the Daytime Running Lights.
phox
Old 08-30-2005, 07:45 PM
KennyG's Avatar
Smile
Rowilson you quote,"Most of the US and Canada don't need them and they are a marketing ploy to sell the modules. Here in the US where I was taught to drive we were told to "read" the oncoming traffic. So if you saw someone in the oncoming lane with their headlights on in the middle of the day there was either bad weather ahead of you (where they came from), they were up all night driving or they were drunk".
1. It's all about..Safety..Safety...Safety!!! Definitely is not a marketting ploy!!!
2. Definitely easier to "read" with lights on.. no matter what you are trying to read...be it vehicles or books. Besides visibility is not something that can be taught!! All the driver training in the world can't teach you "sight or visibility"!! To put it bluntly..."you either see it or you don't" and logically with the lights on, there are times you'll see it better.
Probably because most of the vehicles that you encounter in the daytime don't have DDL's, it wouldn't make any difference. If you were to drive in a Canadian city where the majority of vehicles have them...you would notice a difference on the visibility of the oncoming vehicles. It's kinda like "don't knock it til you try it!!"
KennyG
Quick Reply: Day Time Running Lights
