Dana70 woes
Dana70 woes
Hello all, I lost a rear drivers side wheel and axle and it tore up the housing where the big nut goes on, (gear ratio 307) which appears to be rare and just plain can't find another one to replace it and the only thing I can think of to do is have the housing takin off a 85 dually (gear ratio 456) that I found and have the axle housing takin off from the punkin and put on mine does anyone know if this will work? THANX
It's done all the time. Not necessarily for the reason you are doing it but I have done it to narrow D60's for the front and rear of Jeeps. It has also been done to change offset on the front Dana's. You have to cut the plug welds out of the housing remove the tube and replace with a new/different tube (not as simple/easy as written but very do-able) Also it is best if a housing jig is used to ensure that the tube stays inline with the carier saddles and the other tube. The only other way you are going to save that housing is to cut the damaged spindle off just behind the backing plate flange and weld a new one on. adain a jig should be used. Done right it shoud be strong enough to hold up
Not sure where you are, but if you look in a trucking trade journal you will find companies that can build-up and re-turn spindles on the truck. I thik it is somewhat pricey (around $800) but it works, and you don't have to take the truck apart, etc.
Before is tarted driving my truck it was sitting at the back of our shop with the spindle ripped off. We called one of the spindle guys and came fabbed one up and welded ikt on. You would never know anything happened worked out great
ataboy9026
Dec 6, 2006 09:33 PM
