cylinder head weight
Old 11-26-2008, 10:31 AM
ted_pulliam's Avatar
I've been cautioned against attempting to replace the head gasket on my truck without an assistant. I assume this to be due to the weight of the cylinder head. How much does one weigh?
Also should I have some sort of overhead lift to do this or can me and a couple of friends safely lift the head out? If it is a heavy beast, then the worst case scenario is I would drop it on me, the second worst scenario is that I would drop the head on some hard surface and damage it, a very expensive mistake.
Ted
Old 11-26-2008, 10:59 AM
thumper549's Avatar
If you are the average dude you can do it, I did it, I will think maybe 120 lbs ?
Been 4 years...cant quite remember, but was a strain
Old 11-26-2008, 11:03 AM
KLockliear's Avatar
You will want to use a cherry picker. Makes the job a lot easier.
Old 11-26-2008, 12:15 PM
Thumper549, now that I have a ballpark weight of the cylinder head, I'd like to know a bit more about the gasket replacement. Did you have a shop manual to guide you through the head gasket replacement? I have the Haynes manual.
It seems like the most important points to remember are to drain the coolant, unbolt the thing, gently coerce the head to break loose from the block, prepare the new gasket, check the head for warpage and the head studs for stretching, machine the head and replace the studs if necessary, sandwich the gasket between the block and head and then bolt it back together and refill with coolant.
Though this is a rough description only, have I left anything important out? Oh yeah, the overarching rule of thumb is to keep everything clean while I am working so no dirt makes its way into the engine!
Ted
Old 11-26-2008, 12:50 PM
thumper549's Avatar
You are asking a loaded Q.
Reason for repair ?
Miles on eng ?
You have most of the bases covered
You might want to have it checked for cracks ( very prone )
Buy a Cummings Manuel and NEW head bolts
The Torq. Sequence and angle method is better outlined in the Manuel
Then whilst there....if needed or a up graded exhaust manifold
Pressure check inter cooler.
Clean the radiator The back side can be filthy and maybe flow and pressure check it...
( I hate re dos )
Old 11-26-2008, 01:08 PM
Reason for repair ?Miles on eng ?
( I hate re dos )
The truck has 180k and change on it, and the block to head seam is always wet with coolant at the passenger side front corner of the engine, just under the thermostat. I have to replace coolant in the overflow bottle at the rate of about maybe 1 - 2 cups per month. I've replaced the thermostat but the leakage persists, so I am thinking I may have to do the head gasket soon. thanks for the pointers!
Old 11-26-2008, 01:32 PM
thumper549's Avatar
As I remember... the fustiest thing was a fuel line at the back of the head between it and fire wall.
dont skimp on the bolts
check your DCA after job done ( Ph level )
Old 11-30-2008, 07:40 PM
kalmarsam's Avatar
the head bolt on front rightside of engine is prone to breaking.ie coolant leak on right side front of head. also head bolts should be replaced with new.ps. bare cylinder head no manifolds 150lbs.
Old 11-30-2008, 07:48 PM
thumper549's Avatar
UUmmmppphh !!!
Old 11-30-2008, 08:17 PM
06 DIESEL's Avatar
If you have a cherry picker you are fine taking it off by yourself. When you are putting it back on I would try to find a helper so that you can line it up properly without hurting the HG. I did mine on my 06 mostly by myself, and there was no way I was going to try to take it off without a cherry picker. You have the just of the repair, just make sure that you either get NEW head bolts or get studs. Also, make sure that you torque them down properly, in sequence or it could cause the gasket to not set properly and leaque again. I think your hayes manual would have the proper procedure, if not I am sure I can find the sequence and post it here for you for a 06, should be the same for your truck.
Old 11-30-2008, 08:35 PM
06 DIESEL's Avatar
Here is some info for you from my 06 manual.
File Type: pdf
File Type: pdf
Old 11-30-2008, 08:56 PM
Clunk's Avatar
My neighbor...a big guy, and I took mine off the engine...way too heavy/bad position. Reinstalled with an engine hoist...very nice, easy positioning and didn't mess up the $84 head gasket.
Old 12-04-2008, 09:47 AM
kalmarsam, thanks for this info. Would I be able to easily verify that my right front head bolt is broken? Could I just try to torque it to see if this has happened?
If it is broke, does this mean a major drill tap operation to replace it?
Thanks again,
Ted
Old 12-04-2008, 09:52 AM
Allright, thanks!
Ted
Old 12-04-2008, 09:57 AM
Dennis's Avatar
You might want to read up on "53 Block" and see if this might account for some of the coolant loss also. Just more to think about before diving into a big job.
Quick Reply: cylinder head weight
