cruise control not working
Old Jun 17, 2007 | 02:01 AM
duramjames's Avatar
I spilled battery acid on the battery on the drivers side of my truck. I read here that there is a servo and vacum line under there that works the cruise what am i going to have to do to fix this?Where do i start? I read the manual but it did not say if i could take things apart and clean them or do i have to replace it all?
Old Jun 17, 2007 | 12:14 PM
Stamey's Avatar
It's hard to say until you get in there. The first thing would be to check the vacuum line and make sure it is still intact and pulling vaccum at the servo. This is the most common problem. If the acid got into the servoce then you may need to replace it, around 45 bucks, if memory serves, at the dealer.
I assume you have already verified the electrical is working properly, e.g. the cruise light comes on in the dash.
The next thing, after the servo, would be a clock spring under the steering wheel. Never had to deal with it but others here have.
Chris
Old Jun 17, 2007 | 02:35 PM
duramjames's Avatar
Thanks I did check vacuum line it was eat in to . I cut it and spliced it back moved the vacuum lines a little closer to battery so they would reach and tried it out .It works fine now I will replace line tommorrow when dealership opens. a lot thanks
94 dodge
15
Apr 20, 2012 11:05 PM
Cougsfan
Jul 30, 2007 06:22 PM
Power Ram 250 C
Jul 10, 2007 06:26 PM
GCSS
Aug 14, 2006 12:29 AM
perk
Jul 2, 2004 06:00 PM
