crreaky driverside front wheel
Old Nov 22, 2006 | 12:24 PM
puffmagicdiesel's Avatar
my fron diverside wheel is creaking when i hit the brakes and i had it in park with the wheels slightly turned to the right and facing down hill and i heard it. it does not creak when im in reverse and hit the brakes. but it is also doesnt start right when i hit the brakes if i ease into them it takes about 20 secs. or so. it almost sounds like sheet metal but i have no idea i looked under there and didnt see anything any help would be greatful.
Old Nov 22, 2006 | 12:32 PM
loch's Avatar
Theres not a lot there to make noise, is there clearance for the tires? Id also jack it up and check feel and even the wheel bearings. This might be one those hair ripping out searches.
Old Nov 23, 2006 | 08:17 AM
Rammer64's Avatar
It's quite common for the front springs to creek on turns or bumps while turning. Try spraying some WD40 or lube spray in the upper and lower spring pockets and see if it goes away. Try to get a liberal amount between the spring and pocket.
Old Nov 23, 2006 | 06:43 PM
TOMTOM's Avatar
I'd Double Check Those Ball Joints. Just My .02
Old Nov 26, 2006 | 01:44 PM
found out what it is. it is the bushings on my strut they are both bad but the left side one is gone so iv gotta get em ordered up on monday
RamGazer
Aug 7, 2013 01:30 PM
C.L.S.
Jun 1, 2011 10:18 AM
GSP7
Jun 24, 2010 12:56 PM
Wilbur01
Aug 3, 2009 11:16 PM
jrn
Jul 19, 2009 02:55 PM
